Hi all,
Thank you for your comments in past. I had made few amps and realized that there is no solution using only one amp to have purely three dimensional sound effect. I just came out with my own new ideas. I like class-A mid and treble sound very much but the problem is bass. I had decided why not use two amps to get nice and quality sound effect. I have posted my ideas pic. I want to use two amp. Mid and treble = Class A 50w For BASS = class D 150w. Hope for more ideas and discussion from you all. Best regards Michael |
#2 |
hi space2000,
Ideally, the "crossovers" should be replaced by active filters before the amps. See ESP: http://sound.westhost.com/bi-amp.htm regards
Greg Erskine |
#3 |
I disagree with ESP (and most other authors/builders) on the power requirements of the various frequency band drivers.
I contend that using drivers of the same sensitivity require the same voltage supplied to the driver, irrespective of the frequency range. If the treble, mid and bass drivers are all 8ohm, 90dB/W/m, then they all need 40Vpk to reproduce a transient peak of 110dB @ 1m. When one mixes drivers of different sensitivity and/or impedance, only then should an adjustment be made to the supplied signal voltage to each driver.
regards Andrew T. |
#4 |
I think the ESP article only refers to the spectral content of typical music, not sensitivity or gain requirements. They all need the same gain but tweeters will require less power because less of the music power is in their range.
#5 | |
The transient peak voltage requirement must still be met.
regards Andrew T. |
#6 |
Thanks for answering so many of my questions...
Yep Andrew that makes sense... if gain determines that output should be xV and it is connected to Yohms it is going to require Zamps...regardless of the frequency |
#7 | |
Well the implication you are making is transient peaks in music can occur anywhere in the frequency range, which is true is terms of CD red book standards, but ignores typical high quality music spectra. The latter is the more pragmatic approach. The former is rigourous but over-engineering. I am not suggesting amplifiers should be chosen on average spectral power either, the difference between say bass / mid and treble amplifiers should be less than this implies. The argument regarding voltage is a non argument. It applies whether the c/o point is 100Hz, 1Khz or 10Khz, i.e. it misses the point completely. 100W for below / 100w for above 10Khz is obviously nonsense. |
#8 | |
I believe the transient peaks are very similar when looking/listening at/to a whole range of music. That's where discos fall down. The treble SPL levels are way down on the rest of the frequency range. This leads to gross overloading of the treble and removes all semblance of realism, particularly on female vocals and similar HF content.
regards Andrew T. |
#9 | |
#10 |
Well you are both missing the point completely, some engineers ....... Your saying two 100W amplifiers can be used split at 100Hz, 1kHz or 10kHz and it makes no difference, it is "technically correct" because of voltage capability, you cannot see the wood for the trees. At 10kHz it only makes sense for white noise and fried tweeters. FWIW : Take 100w / 400w amplifiers , the 400w has x2 voltage capability. Take 4 x 100w amplifiers optimally split, you can argue about this but lets use pink noise, so they all need ~ the same width in octaves. Say 115Hz, 640Hz, 3.5khz c/o points. (edit : do you seriously think 4 x 100w is correct for 5khz, 10kHz, 15kHz ?) What theoretically is the maximum equivalent voltage swing of these 4 amplifiers into a 4-way speaker, ie. what single amplifier offers the same maximum voltage capability in each band simultaneously ? The answer is 1.6kW ....... even though max average = 4 x 100W, (edit) wideband and only 100w continuous sine wave power. So should the input to the 4-way active crossover be limited to be the equivalent voltage capability of each amplifier ? of course not, unless the only input allowed is a sine wave, where it makes sense. |
| L pad and series resistor effect on sound | Frankx | Multi-Way | 4 | 31st October 2005 03:10 PM |
| Quality Control differences = variations in sound quality? | KT | Class D | 0 | 14th November 2004 06:51 AM |
| do speaker grills effect sound | busterno1 | Multi-Way | 15 | 28th March 2004 06:14 PM |
| Does solder quality have an adverse effect on sound? | Corn-Picker | Solid State | 31 | 20th August 2003 04:38 PM |
| Inductor awg. Does it effect sound/x-over points? | KevinLee | Multi-Way | 1 | 15th December 2002 11:01 PM |
| Page generated in 0.11347 seconds (83.13% PHP - 16.87% MySQL) with 11 queries |
