Old 26th June 2008, 01:17 PM   #11
Bi-amping normal two way speakers only makes sense under certain
circumstances, otherwise you are spending a lot of money driving
a pair of tweeters.
These are :
The power amplifier does not have fantastic current delivery.
The power amplifier is stereo with a shared supply.
In this case bi-amping with the same stereo amplifier per channel works well.
New crossovers are not required (unless they are not bi-ampable).
Other options are a smaller (than the other) 1st order high passed
input amplifier for treble but the gains of the amplifiers must match.
/sreten.
Old 26th June 2008, 01:33 PM   #12
Nordic is offline Nordic  South Africa
Nordic's Avatar
well my good amps are all diy, so gain matching is no problem...
I would like to retain my DX HRII amps for the tweeters, as they are very clear sounding, yet very smooth on the ear.
I think the bass on my sytem gets a bit compromised at higher volumes due to the low output from the amp (in the 40W area)... combined with inefficiency of about 86db/W
Question... is it advisable to make up for sensitivity diffirences between woofer and tweeter in the amps?
Old 26th June 2008, 01:39 PM   #13
Originally posted by Nordic
is it advisable to make up for sensitivity differences between woofer and tweeter in the amps?
the gain of the amp must exactly match the sensitivity of the driver.
regards Andrew T.
Old 26th June 2008, 01:44 PM   #14
Nordic's Avatar
Schweet... it makes sense in deep and deliberate way...
Old 26th June 2008, 03:28 PM   #15
Question... is it advisable to make up for sensitivity differences between woofer and tweeter in the amps?
No. Because this implies changing the crossover design.
/sreten.
Bi-Amping.....Which one where? THUMP LUMP Solid State 3 17th December 2007 08:24 PM
Bi-amping keyser Multi-Way 2 10th February 2005 11:57 AM
Bi-amping diyman Multi-Way 9 10th January 2005 07:55 PM
Tri amping SOZ Magura Pass Labs 6 8th January 2004 08:51 PM
Bi-amping set up? MikeW Pass Labs 8 13th November 2003 02:27 AM
Page generated in 0.08541 seconds (77.25% PHP - 22.75% MySQL) with 10 queries
