Old 24th June 2008, 08:39 PM   #1
darian is offline darian  France
Default A question about diamond buffers
Hello everyone,
Recently (since this morning actually) I got very interested in diamond buffers and found several schematics. I understand the principle for the Walt Jung version and some derived ones but not this one for which I post the schematic. I may be a dumb question but how is the second stage correctly polarised? To me it looks like a class B or even C stage... Probably I'm missing something in the design...
Old 24th June 2008, 08:41 PM   #2
The Walt Jung design is limpid, with the emitter resistors on the first stage setting the second one in class A...
Old 24th June 2008, 08:43 PM   #3
And finally this one used in an Accuphase amplifier is very elegant with the first stage biasing the second one...
Old 24th June 2008, 11:14 PM   #4
juma is offline juma  Serbia
juma's Avatar
Take a peek here:
http://www.diamondstar.de/dDB_design.html
Old 24th June 2008, 11:43 PM   #5
Thank you for your answer,
These ones have the emitter resistor for bias as it should. I just wondered about the scheme without them. I found it on a forum about headphones. They could be Sijosae design or something. I just wondered about the crossover distortion in a strict class B like that. It is better in class A.
And if the Vbe of the first stage is lower than the second, you get a nice class C one.
I may be wrong but I wanted a confirmation.
Anyone?
Old 24th June 2008, 11:46 PM   #6
And I wanted to share the Accuphase one which I find very interesting with the autobias acting like a faint NFB too.
Very elegant...
Old 25th June 2008, 12:17 AM   #7
forr is offline forr  France
forr's Avatar
Hi Darian,
You are right, the first schematics you show is wrong.
I would be curious of the results obtained with the Accuphase circuit.
Old 25th June 2008, 12:39 AM   #8
Banned
Darian
I read the circuit (1) like this: -
The circuit is symmetrical and collector voltages in the first stage will be equally offset from the supply rails when the Hfe of the transistors is equal.
Since the bases of the input transistors are at the same voltage (connected), the differential voltage between the collectors is Vbe(337) + Vbe(327). This is insufficient to bias the second stage into conduction, because of the voltage drop across the 2*4R7 emitter resistors and because the transistors used are identical to the ones in the first stage.
So this is a class B push-pull amplifier and will have pronounced crossover distortion.
w
Old 25th June 2008, 01:01 AM   #9
Thanks for your answer,
So I was right about it. I guess no one complained about it in the headphone forum (Headwize I think). There may be some people listening to that badly designed circuit and thinking it's a good one. Too bad for them...
Anyway, I have my answer. If someone wants to try the Accuphase circuit, I'd be pleased to hear some feedback. It's so smart and so simple at the same time.
Thanx
Old 25th June 2008, 09:10 AM   #10
Banned
Sorry
I was about to go to bed when I wrote that. I went to sleep and woke up thinking about it.
In both instances this should read emitter, not collector.
This is 2 cross-coupled emitter followers, so voltage gain < 1. It's purely a current buffer.
Since the Vbe's of the stages are likely to be close, the xover is probably fairly smooth.
If you wanted to run it AB, you could do this:-
w
HDAM / Diamond Buffers Q RnR Solid State 0 21st April 2009 10:59 PM
A question about diamond buffers darian Analog Line Level 3 24th June 2008 08:38 PM
Diamond buffers Nordic Parts 7 13th March 2007 03:13 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 07:32 AM
Diamond buffers w. CFP outputs Christer Solid State 39 27th January 2004 12:08 AM
Page generated in 0.11009 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
