Hi!
My old Marantz amp (PM750) is slowly dying, so i need to change it. I could repair it, but it's quite complicated and it uses very strange audio cables (anyone know what they are? they go from inputs to preamp). A friend kindly offered me his Quad405-2 layout with some mods. I must say i never heard real 405, except brother's which was built with very bad material and mods are probably not well done. Can someone please comment the sound of 405-2? Is it high quality amp and can be compared to "better" amps? What i need is nice neutral amp that can drive my passive KRK ST8 (120Wmax) studio monitors. At some occasions i will use tube preamp with it, to smooth the sound a bit (this monitors sound a bit harsh). In short words; do you suggest making it for my needs if i get lots of material for free and some help from very experienced friend (he built at least 20 Quads)? Btw, is it possible to replace input op amp with discrete version? How much gain does it need? I have some very nice sounding DOAs. Miha |
#2 |
...Hi, Miha
My first Quad 405 was built in 1981 , I remember , voltage rail only 24 V with 2N3055 transistors . Not long time ago I start to make a new improoved (reborn ) Quad 405 . Here you can find some pictures http://i27.tinypic.com/71h6oh.jpg voltage rail +/-60V and another variant http://i27.tinypic.com/11m40pg.jpg and this one with lateral mosfet http://i26.tinypic.com/1smhrk.jpg finally , the case http://i28.tinypic.com/wr19nt.jpg . Sorry for my poor english
#3 |
Hi Alex!
Nice amp! Congratulations. I think i'm going to build one myself(now waiting for the parts. How warm are you driving it? I mean your heatsinks are not very big how do they handle the heat? By the way, where did you buy the LM and the power transistors? |
#4 |
I'm quite sure it's possible to change op amp with non-inverting discrete version. Anyone have experiences with this kind of mod? I have some experiences with Leach amp, can someone please comment how it sounds compared to Quad? Are they close in sound? I must say i don't have good experiences with brother's Quad405II. Highs are a bit muddy and "sweet". Lows are not good either, they are somehow exagerated, boomy at around 50 to 80Hz. But amp is built with bad material,so i guess this is the reason for problems i mentioned. Any more thoughts about sound of this amp when is well built? Miha |
#5 |
I've never been too thrilled with the sound of the Quad 405. Sonically I think (I know !) you can do much better. The whole reason for the current dumping philosophy was to enable a "slow" pair of outputs to be used with no adjustment for quiescent current. From a technical view it was a truly radical new way of thinking. If you want to build one you must stick to the original concept and design. The component values are crucial for it to perform as it does. Regards Karl |
#6 | |
Magneto the Gravity Man
It's a little harsh to say the the Quad 405 were built with 'bad material'. It was pretty much state of the art when it was released. My first was a low serial number, about 1066 I think, and like a lot of Quad stuff, it did sound warm and 'flat', the Quad sound. My later 2 both sounded a lot more lively. All benefitted from change of I/O connectors. There are pages and pages of mods for these amps including upgrading the op-amp. good luck Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#7 |
it was not original Quad, sorry, i should say it. A friend built it for my brother with what he had at hand. Can you compare it to modern amps? Miha |
#8 |
Based on the schematics I've seen the whole discrete opamp version has been done, Quad called them the 606, 707 and 909.
There is still an op-amp in the circuit, but it's role is that of a normal DC servo. Stuart |
#9 |
Hello Alex mm,
Just been having a closer look at your handiwork -- very nice job indeed. The "one with a lateral" got my attention (Think you know why Regards Karl |
#10 |
Hi , Mooly
Sorry, for delay , but I'm bussy at my job . So, let's see first schematic http://i32.tinypic.com/f0opom.jpg and then one of the PCB 's http://i32.tinypic.com/24gnnud.jpg , the rest should be clear |
| Opinions on the best sub.... | Jonny Hotnuts | Car Audio | 10 | 31st December 2007 03:22 AM |
| Opinions on.... | Sch3mat1c | Solid State | 9 | 26th November 2003 09:50 PM |
| Opinions on this amp...? | DrG | Solid State | 36 | 15th September 2003 09:18 AM |
| Any opinions on this amp? | steve jones | Solid State | 6 | 2nd August 2002 01:41 PM |
| Page generated in 0.10563 seconds (81.10% PHP - 18.90% MySQL) with 11 queries |
