insulation from heatsink help please
Old 22nd June 2008, 01:57 PM   #11
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally posted by megajocke
Does anyone know where to find insulators for TO-264 cases? (like for MJL2119x, 2SC5200, FJL4215 etc.)
I use TO-3 mica cut to size and punch a new hole. I haven't had a problem. They are cheap and easy to come by.
Old 22nd June 2008, 03:26 PM   #12
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Try RS Components at www.rswww.com
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 22nd June 2008, 06:28 PM   #13
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Plastic screws are also helpful.
Old 22nd June 2008, 06:37 PM   #14
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
I remember nylon screws as relativ weak.
regards
Old 22nd June 2008, 10:26 PM   #15
megajocke is offline megajocke  Sweden
megajocke's Avatar
I'd use those top hat bushings, metal screws and compression (bell?) washers to get higher mounting pressure and reliability.
MJL: Thanks for the tip! Saw a picture of someone who did that for TO-247 but didn't think they would be big enough for TO-264.
Old 22nd June 2008, 10:30 PM   #16
I use the IRFP240/9240 and they have insulated bushes in the transistors.
Old 22nd June 2008, 11:02 PM   #17
megajocke's Avatar
Of course, but the original poster asked about TO220.
The TO264 cases (like Onsemi MJL series, Toshiba 2SC5200, Fairchild FJL4315) have these plastic parts too. TO126 and similar packages (BD139, MJE340, 2sd669) have them too IIRC.
Old 26th June 2008, 10:38 PM   #18
d3imlay is offline d3imlay  United States
Use a 100W light bulb in series with the line cord on power up to protect against faults. The light bulb will save you, a variac won't.
Old 27th June 2008, 07:44 AM   #19
R.I.P.
start with a 40W bulb, and if Ok, then work up through 60W, 100W and if necessary 150W bulbs.
regards Andrew T.
Old 27th June 2008, 04:39 PM   #20
Pbassred is offline Pbassred  United Kingdom
Pbassred's Avatar
Send a message via MSN to Pbassred
unfortunatly the amp blew up on the 3rd or 4th start after the covers went on!
Jeeees! I only asked
https://www.facebook.com/dave.potter.5815
insulation from heatsink help pleaseHide this!Advertise here!
copper diy insulation nicoch58 Parts 4 30th June 2009 10:00 AM
Functional Insulation ralphs99 Power Supplies 0 29th May 2006 10:55 AM
Insulation on LM3875's enzedone Chip Amps 12 23rd November 2005 03:47 AM
magnetic insulation akhlan Multi-Way 6 10th October 2003 12:12 PM
insulation pads Matttcattt Parts 0 11th June 2003 09:46 PM
