Old 18th June 2008, 07:56 PM   #1
haseeb is offline haseeb  India
Send a message via Yahoo to haseeb
Default 2sa970/2sc2240 sudden HFE DIP
Hi All,
I was working with an input stage using CFP method .
I found there is sudden drop in hfe, the gain is very minimal.
Then tried to touch some pins of the active and passive devices for any dry solder and for some pin there was sudden increase in gain.
I checked for dry solder which is just fine.
Then I tried to drill down what is causing the dip in gain found that when I touch collector pin or emmiter pin of any 2sa970 or 2sc2240 there was a dip in gain and it never come normal until retouch or short circuit Emiiter-collector pin.
Why is this happenning any Idea.
I am working on 34+ve 34-ve rails
regards,
Haseeb
Old 18th June 2008, 11:32 PM   #2
unclejed613's Avatar
it might help to see a schematic of the circuit in question..... transistors don't just change gain for no apparent reason unless they are being over or under biased.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 20th June 2008, 11:05 PM   #3
nigelwright7557's Avatar
Default Re: 2sa970/2sc2240 sudden HFE DIP
Originally posted by haseeb
Hi All,
regards,
Haseeb
I had a similar problem on one of my amp builds.
The output would start at zero then slowly go to B- !
One of the input resistors had a dry joint.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 21st June 2008, 07:23 AM   #4
Elvee is offline Elvee  Belgium
Hi All,
regards,
Haseeb
Looks like you are experiencing VHF or UHF oscillations: this is typical behaviour when a circuit is on the verge of oscillation. When the circuit oscillates, there is an apparent drop in DC/LF gain.
To ascertain this is the case, you can solder 1nF ceramic caps directly (short leads or no leads) across the base and emitter of each transistor.
This will quash any spurious oscillation and have little impact on the LF behaviour.
LV
Old 23rd June 2008, 09:33 PM   #5
Hi Elvee,
Looks you are exactly there.
Yes, there is LF gain.
Yes , I too felt the same and tried to put some pf valued cap across collecter and emmiter , I found there is change in frequency.
I'll try what you suggested and get back soon.
Thanks Elvee
Old 26th June 2008, 11:29 PM   #6
Hi Elvee,
I tried your work around but did not helped.
I am redesigning my circuit.
Haseeb
spice models for 2sa970/2sc2240? bmcevers Solid State 14 23rd July 2010 06:56 AM
transistors 2sa970/2sc2240 pdul Parts 8 14th June 2009 06:59 PM
WTB: 2SA970 & 2SC2240 within Canada abzug Swap Meet 9 16th January 2008 01:23 AM
Spice models of 2sa970 and 2sc2240 hjelm Parts 4 16th February 2004 09:27 AM
2SA970 & 2SC2240 pinouts or datasheets? JoeBob Parts 2 8th October 2003 12:04 AM
Page generated in 0.08607 seconds (76.85% PHP - 23.15% MySQL) with 10 queries
