Old 1st March 2011, 04:29 PM   #41
Nico Ras's Avatar
Yes that is one way of doing it. and yest to make a passive band reject is equally simple. Unfortunately if you have a passive volume control in the same loop, you will be changing the impedance continually and also change the frequency of the filter and some buffer (op-amp) will be necessary.
Although theoretically cutting the mid as opposed to boosting the bass and treble would have a different effect on your perception.
First go try it practically by using the equaliser of your win-amp or media player. then decide if this is what you want and we will give some thought to how we will solve your problem practically.
Old 1st March 2011, 04:40 PM   #42
Nico Ras's Avatar
Is this what you have in mind perhaps?
Old 1st March 2011, 04:44 PM   #43
Nico Ras's Avatar
I remember Quad22 or 33 had a single knob tone control referred to as a tilt control, either cutting the bass or the treble around a fixed pivot frequency. Someone here may have that schematic and willing to post it.
Old 2nd March 2011, 04:26 AM   #44
chuck55 is offline chuck55  United States
Charles Darwin, that is EXACTLY what I am attempting here.
The eq in discussion has bass / mid / treble/ cut or boost. By cutting all 3, I effectively get a boost at 100hz and 4,000 hz. problem is I am trying to change the upper boost to 10,000 hz. No success in figuring out how to do it though
Nico Ras: Just wanted to know if your equation gave you the same 12.9 hz high-pass filter? That is what I calculated from it ..... if I did it correctly.
You can tune it to any desired frequency
So how do I do this?
I am putting my passive TDK volume pot before the tone control. So is this still a problem?
I am not quite sure I understand your last question.
I am trying to change the upper boost to 10,000 hz.. If you look at the graph on that page, you can see the intersection of the mid and treble is 4,000 hz. I want to increase that to 10,000hz. Any thoughts????
Tone control pre-amp digi01 Chip Amps 16 13th June 2011 07:18 AM
Loudness Control Calc - Help Please LinuksGuru Tubes / Valves 0 14th December 2008 03:43 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
Looking for info on loudness control normanjr Tubes / Valves 5 26th September 2006 04:43 PM
loudness control maylar Solid State 6 28th March 2004 04:12 AM
Page generated in 0.08501 seconds (73.50% PHP - 26.50% MySQL) with 11 queries
