Pre-Amp ...... Help wanted with Circuit Pre-Amp ...... Help wanted with Circuit - diyAudio
Old 18th June 2008, 01:04 PM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Pre-Amp ...... Help wanted with Circuit
Hi All,
I am looking for a circuit I have seen somewhere !!
I can only describe it as using NPN/PNP pairs in a cross coupled circuit with a +/- supply rail in a sort of diamond configuration and symmetrical.
Any ideas?
Andy
Old 18th June 2008, 01:07 PM   #2
forr is offline forr  France
forr's Avatar
Hi Poynton,
You may refer to Dick Marsch' or Hafler circuits, two NPN and two PNP, low distorsion.
Sand cat https://en.wikipedia.org/wiki/Sand_cat
Keep zener !
Old 18th June 2008, 01:47 PM   #3
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
based on what i think you're saying, i agree with forr ...
go to the hafler site and look for the DH101 preamp manual.
is that what you mean?
mlloyd1
Old 18th June 2008, 02:54 PM   #4
poynton's Avatar
Hi.
Thanks for that suggestion.
The RIAA section looks like what I was thinking of although what I had in mind was a buffer.
Andy
Old 19th June 2008, 01:35 PM   #5
poynton's Avatar
Originally posted by forr
Hi Poynton,
I cannot find any references to " Dick Marsch" here or on Google.
Anyone?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 19th June 2008, 02:29 PM   #6
lineup is offline lineup  Sweden
lineup's Avatar
Try Dick Marsh or Richard Marsh
If you search with www.google.com or here in forum http://www.diyaudio.com/forums/search.php
He appears to have this Website: marshsounddesign.com
with products like:
Mr. Marsh is also very well known in Audio for this work,
together with some of the world's leading amplifier designers:
Walt Jung or Walter G. Jung and our own John 'JC' Curl
Picking Capacitors - Walter G. Jung and Richard Marsh, 1980
http://www.reliablecapacitors.com/pickcap.htm
Omitted factors in audio circuit design
John Curl
This paper appears in: Acoustics, Speech, and Signal Processing, IEEE International Conference on ICASSP '78.
Publication Date: Apr 1978
Volume: 3, On page(s): 263- 266
Abstract
Traditional measurements of audio amplifiers use test signals that do not represent conditions of actual use.
TIM measurement is one factor in improving the correlation between audible and measurable differences in circuitry.
Additionally, many circuits incorporate non-linear elements that appear to be distortionless at conventional measurement frequencies, but can be significant sources of distortion when subsonic or supersonic frequencies are included.
This paper describes some of these non-linear elements and their effects on actual circuit performance.
John Curl & Walt Jung: A Real-Time Signal Test for Capacitor Quality, 1985
http://waltjung.org/PDFs/Picking_Capacitors_1.pdf
http://waltjung.org/PDFs/Picking_Capacitors_2.pdf
Walt Jung - Classic Articles
Welcome to Walt Jung website
Lineup
lineup
Pre-Amp ...... Help wanted with CircuitHide this!Advertise here!
Simple Magic Eye Circuit Wanted poynton Tubes / Valves 8 26th November 2014 09:02 AM
DNM Power Amp Circuit Diagrams Wanted mozfet Solid State 3 29th August 2009 09:10 PM
PP EL34 circuit wanted Norris Wilson Tubes / Valves 3 9th August 2007 11:29 AM
Help! Nokia 7210 circuit diagram wanted! Mr. Alex Digital Source 2 3rd July 2004 07:39 PM
6h30 dac output circuit wanted..anyone? tone Tubes / Valves 19 6th February 2003 05:07 PM
Copyright ©1999-2017 diyAudio
