Old 16th June 2008, 11:21 PM   #1
Frosti is offline Frosti  Israel
Arrow 110v power amp with 220v transformer, effects sound?
Hi, i got 5x220w 5.1 parasound hca-2205 with 110v and the mains here are 220v!
i also got 110/220 transformer+current conditioner
how would that effect sound?
Thanx!
Old 17th June 2008, 12:11 AM   #2
nigelwright7557's Avatar
Default Re: 110v power amp with 220v transformer, effects sound?
Thanx!
Should sound great !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 17th June 2008, 02:31 AM   #3
ventle is offline ventle  Norway
As long as the transformer is able to supply the required power it shouldn't affect the sound at all
Old 17th June 2008, 02:58 AM   #4
As ventle said, as long as the transformer supplies enough current, then it should work fine. In fact, it will provide a level of hum reduction from the ac line as you are now feeding the amp a balanced ac power signal.
Peace,
Dave
Old 17th June 2008, 03:13 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
It's a complex subject to discuss,much like"how AC main supply will affect my system,in term of sound?"
Old 9th October 2009, 08:37 PM   #6
Default You can internally convert the HCA-2205 to work on 230v
I'm trying to find the schematics/service directions right now, but the amp is internally able to be wired to accept 230v input. I've contacted Parasound, as I've just moved from US (115v) to the UK (230v) Tony just got the UK distributor to email me a local service shop (that isn't all to local). So my search continues...
I've opened the amp up and the board has a few references to 230v, but no straight forward directions, all my other equipment were clearly marked internally for the rewire.
-Paul
Old 9th October 2009, 09:49 PM   #7
Speedskater's Avatar
Do we have any 50Hz / 60Hz problems here?
Kevin
How do I convert my 110V B+K amp to run on 220V power? mixersoft Solid State 48 15th September 2009 12:12 PM
Solid State 110V to 220V transformer affects audio? Frosti Solid State 8 4th May 2009 08:39 AM
How to rewire Soundcraftsmen Pro Power 4 from 220v to 110V? warrenhud Solid State 1 7th April 2009 07:33 PM
Power Tools: 220V v 110V rif Equipment & Tools 5 22nd June 2005 05:39 AM
Aleph 3 with 110v->220v transformer roee Pass Labs 5 4th May 2004 09:59 PM
Page generated in 0.09292 seconds (76.08% PHP - 23.92% MySQL) with 10 queries
