My recent posts have me very interested in trying to lower my amplifier's DC offset as much possible, but my amp didn't come with a trimpot for that purpose.
Based on the attached circuit, is adding a DC offset trimpot as simple as putting one in a particular spot between two transistors? Is it really that easy, or do you need to create a whole new circuit? -Bryan |
#2 |
P2 would normally adjust the output offset. But this LTP has a current mirror and P2 becomes a VAS bias adjust only (maybe?). Try changing P2 and tell us what happens.
regards Andrew T. |
#3 |
This is one way of doing it:
http://headwize.com/ubb/showpost.php...=42615&fpage=2 A pot instead of (or in parallel with) R3/R4 can also tune the DC-offset. |
#4 |
I don't recommend unbalancing the LTP.
regards Andrew T. |
#5 |
In my manual the P2 pot is called a "Balance control"and its purpose is as "a distortion control that requires specialized test equipment to adjust".
Not knowing exactly what P2 does, I hate to change the factory setting as the pot is fixed with a dab of paint. I like the idea of substituting a pot for R3/R4, I'll let you know what the outcome is... -Bryan |
#6 |
I need some help deciding how to place the trimpots mentioned above........Which would make more sense?
- Replace both R3 and R4 with separate trimpots (I'm thinking 100ohm to give me some range). - Or replace just one of the resistors with a trimpot, and dial it up/down to in to zero out the DC? I would think it tricky to keep separate pots in 'synch'. Thanks in advance for advice.......Bryan |
#7 |
Just how much is your DC offset now?
Would it make any sense to match a new pair of diff transistors and see if that helped? While changing R3 or R4 will lower the DC offset isn't that going to be counter productive because the pair would no longer be matched? Would it be possible to add a DC servo to the circuit to lower the DC offset? |
#8 |
It's not bad now (13mv, 20mv) but when I bridge the channels it goes to 80mv. My other amp a Musical Concepts Xl280 w/PA3 with 1mv, so I'd like this amp above to be equally low.
I was just sorta hoping there was an easy method to add a DC offset adjustment to a Hafler 1200/9130 that doesn't have one. In terms of re-matching the input transistors, I would love to do that. Too bad noone online offers a trustworthy service of matching transistors for audiophiles(!). Or do they? |
#9 |
I think your safest bet is to follow the instructions in the link above, not adding a pot instead of R3/R4. It was just an example of how it can be done. A trimpot/resistors from rails to negative input will do the same job (manually) as a DC servo. Though it's not cheaper than a servo circuit, it's more straightforward.
Your P2 is to set the bias current to the VAS transistors and should have nothing to do with offset. |
#10 | |
I have a cheap multimeter that measures the gain of transistors.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| create a DC offset value for non-inverting amplifier | finding_apple | Parts | 4 | 4th June 2008 09:01 AM |
| 1k 1/4W trimpot old style hafler | eyoung | Swap Meet | 0 | 1st December 2007 12:37 AM |
| Hafler 1K trimpot fried - how do I replace? | HaflerFreak | Solid State | 2 | 14th August 2007 12:09 PM |
| 4 gang pot / trimpot needed | deandob | Swap Meet | 1 | 26th April 2005 11:52 PM |
| ZEN question inputImpedance Trimpot etc | Smithers | Pass Labs | 5 | 4th April 2003 02:09 AM |
| Page generated in 0.11922 seconds (76.66% PHP - 23.34% MySQL) with 11 queries |
