Old 13th June 2008, 02:00 AM   #1
other3 is offline other3  United States
Default Carver M500-T Unit fuse
The slow blow fuse blew in my unit, at least a voltmeter says it will not conduct. What is the value of the fuse. I can't make it out. I've had the unit for over 30 years and never blew the fuse. Had to fuse my old ARs.
Would appreciate any help. I'm a newbee to this site.
Old 13th June 2008, 03:33 AM   #2
Bigred is offline Bigred  Canada
The fuse is a 10amp slow blow. Word of caution: You run the risk of further damage if you go replacing it thinking everything will be fine. If you wanna take your chances with trying a replacement so beit but if it blows again take the amp to an EXPERIENCED CARVER tech.
Old 13th June 2008, 03:38 AM   #3
djk is offline djk
djk's Avatar
If that fuse blows the amp is damaged, do not replace it.
Check the triac for shorts, then the rectifier diodes in the supplies, last, check the outputs.
Candidates for the Darwin Award should not read this author.
Old 25th October 2008, 07:35 AM   #4
test account thank
Old 26th October 2008, 09:32 AM   #5
jaycee is offline jaycee  United Kingdom
If he's had it 30 years it's possible the fuse has just blown from being "tired". I would recommend replacing it, but power up with a bulb in series with the Live/Hot line (see elsewhere on the forum). If the bulb glows bright, then the amp is damaged.
If you have further problems, get hold of Anatech from this forum - he is the man when it comes to Carver.
Carver M500 power amp start up problems. AMV8 Solid State 7 13th May 2008 12:59 PM
Carver M500 Power Supply jpanwell Solid State 5 27th November 2007 04:56 AM
carver m500-t schematics morpheus82 Solid State 4 23rd April 2007 09:54 AM
digital amplifier for rokulabs m500 greg1790 Digital Source 0 27th December 2005 05:37 PM
Carver have internal fuse to protect channel dead? doggie750 Solid State 13 7th July 2005 02:25 AM
Page generated in 0.08706 seconds (78.55% PHP - 21.45% MySQL) with 10 queries
