going from XLR to unbalanced, is this ok?
Old 14th March 2003, 06:59 PM   #1
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Question going from XLR to unbalanced, is this ok?
Is it okay to use shield and positive only on the XLR ? Just shorting the negative to ground and going to RCA that way.
tia
Old 14th March 2003, 07:23 PM   #2
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Assuming a "standard" XLR configuration:
Pin 1- gnd
Pin 2- hot (+)
Pin 3- not (-) couterphase
Pin -2 tip
Pin -3 sleeve
Pin -1 sleeve (optional)
In most equipment you should be aware that you will encounter a 15 dB difference between signal levels.
Coming out of balanced and into RCA unbalanced a T-Pad works nice for padding the level down.
Going form an unbalanced (-10 dB) output to a +4 dB input may require an op amp to bring the level up if the input stage doesn’t have enough gain.
You should also watch out because there is still quite a bit of gear floating around setup for a +8dB input level reference (Sony comes to mind).
Other things to watch out for are balanced output stages that are transformer coupled will sometimes overshoot if they are fed into a high impedance input. A simple solution is to stuff a ¼ watt 600-ohm terminating resistor inside the XLR (across pins 2 and 3)cable connected to the output.
You should be careful here too that you will sometimes think you’ve made up enough gain by turning the input/output knobs up or down but may be introducing operating outside of the optimal SNR range and introducing distortion.
http://www.jensen-transformers.com/ has some great circuits and white papers showing conversions in both directions using their very high quality transformers.
-Dave
going from XLR to unbalanced, is this ok?Hide this!Advertise here!
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 12:03 AM
OFC unbalanced interconnects: what's the use?! Bricolo Parts 1 29th September 2004 07:19 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced janey Pass Labs 1 22nd December 2001 11:44 PM
Unbalanced input SOZ? paulb Pass Labs 5 27th September 2001 05:01 AM
