hi,
i saw class A amp ZEN-XA, 120w into 8ohms. anyone knows about this amp? how is your comment on this amp sound qulaity? is there anymore web can see this amp ppls build? http://www.kk-pcb.com/zen-xa.html thank you michael |
#2 | |
Also how much heatsinks? Those 2 factors certainlyn will affect Sound Quality. There are no 2 amplifiers, from same schematic, that is the same. .. as there are no 2 transistors, or resistors, or transformers or capcitors ... that are or can be 100 % same = perfectly match regars Lineup
lineup |
#3 |
#4 |
In comparisson my wall mounted room heating pannel is only a bit over 200W
#5 |
hi,
what is the heat sink size require for this amp? thank you |
#6 | ||
This is a Nelson Pass amplifier. He would be the best man to ask. Hope he reads this. I Know he will Even if your topic should better be in 'Pass Labs' forum. What I think is: this is an Class A amplifier, with requirement Clean and powerful PSU. And quite impessive heatsinking. Lineup, me, and some other clever guys, usually put it like this: Quote:
connect an amplifier, without power supply to your speakers. What do you hear? The power comes from Power supply. Amplifier can not make any power, at all. Which many forget about. If power supply is Strong & Good= amplifier can put out strong & good power. If PSU not strong .. amplifier can not put out strong power. Simple isn't it!! Power supply sets the LIMIT for good and strong output power. Not the amplifier. Amplifier can be a good or less good Power handler. Serve some power. But if power to handle is not there, amplifier can not do much. ================= To make an analogy. The cook makes the food. In the back of restuarante. The waiter carry, handle, the food to the restuarant customer at the table. If there is no good food to deliver, the waiter (amplifier) can not give the customer some good food. Regars, Lineup
lineup |
#7 | |
Electrons are yellow and more is better!
Wanted temperature of the heatsink? The room temperature? If you know those parameters you can calculate have many deg C/W you'll need in the heatsink.
/Per-Anders (my first name) or P-A as my friends call me |
#8 |
I do not think this has Nelson's blessings. This company is making
money off these circute boards. I think this has been talked about before this is not right to put it mildley. I am not positive this is a Pass amp oh! the active Alph current source is stolen from Pas. But like this dude's Tube Zen amp it may not be a Pass amp - This dude tacked a 6c33c on a zen Amp as an input buffer totaly crazy! |
#9 | |
hi peranders, Power dissipation? =500w (as i have seen on the circuit) Wanted temperature of the heatsink? = means highest temp of the heat sink? if it is then should not be more then 45c after get hot. The room temperature? =here is 28c thank you for helping me. |
#10 |
45-28 = 17C Rise for 500W = 0.034C/W
and that is without package or issolator derating..... IT IS HUUUUUUUUUUUUUUUUUUGE |
| Interesting IGBT for class d... | fredos | Class D | 45 | 9th October 2011 10:01 PM |
| Simple Class A design. Interesting? | stigla | Solid State | 46 | 13th March 2006 04:00 PM |
| Interesting new (mis)utilization of class D devices | itsmrdavid | Everything Else | 8 | 6th September 2005 09:32 AM |
| Class D LM4680 looks interesting... | AAXenoStrange | Class D | 0 | 3rd February 2005 10:42 PM |
| Page generated in 0.11239 seconds (81.96% PHP - 18.04% MySQL) with 10 queries |
