Old 13th June 2008, 09:00 PM   #31
Depending on how hot they get IMO determines if you need a fan or not.
I've gotten one of these sinks somewhat-hot with an 80W TEC to test, and it does just fine without a fan, but a fan makes a huge difference, and hardly gets warm. These heatsinks to me look like they were meant to be fan cooled because the fins are close together.
I've used fans on heatsinks in an amp that are meant just for convection cooling, with a bit wider fin spacing, and the fans always make a significant difference. A little wasted air IMO isn't a big deal.
Now for the amp I'm building, I'm using regular NJL/MJL4281/4302's, however, if I build a large power supply, amp, or whatever, I'd like to mount some monster transistors with the other sinks I have.
Old 13th June 2008, 09:43 PM   #32
megajocke's Avatar
Originally posted by AndrewT
Jacco,
you seem very sure, but I disagree.
The sink will waste too much forced air in those big gaps.
I agree that it would be possible to have more fins in there if using it for fan cooling but that would need more material - if it's good enough for the intended application why make it heavier and more expensive?
can't find good complementary transistors keantoken Parts 28 12th September 2006 11:22 PM
High-Voltage 350-400V Complementary Transistors for VAS :needs info ? Workhorse Solid State 9 30th August 2006 01:37 AM
Complementary med pwr transistors? janneman Parts 22 16th June 2004 08:18 AM
complementary transistors needed sss Solid State 2 25th October 2003 01:20 PM
Page generated in 0.07787 seconds (73.06% PHP - 26.94% MySQL) with 11 queries
