just found back a quick drawn schematic of my amp
Old 14th March 2003, 02:32 PM   #1
hugobross is offline hugobross  Europe
Default just found back a quick drawn schematic of my amp
I've designed this amp some months ago, it worked well. The sound was good, but I still haven't finished the whole case (a little bit out of time and money).
Attention! one transistor (T17) in the protection circuit is placed incorrect!! The pcb is correct! I've used other output transistors than shown in the schematic!! (BDV 66 - BDV67 I think) I've also experimented with the amount of bias diodes, the value of R28 and the adjustable CCS to get the right quiescent current.
Any comments are welcome.
best regards,
HB.
Old 14th March 2003, 02:34 PM   #2
the pcb:
Old 14th March 2003, 02:38 PM   #3
this was the first version of the pcb; this is incorrect! but it might be a good guideline to place the components.
Old 14th March 2003, 06:51 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Nice circuit.
Old 15th March 2003, 09:53 AM   #5
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Maybe pot R23 could have a zener from top to bottom so the voltage across it's length, and consequently the setting of ccs T14 won't vary with supply rail variations. The resistor below the pot that goes to 0v (can't see the schematic while replying!) may need to be lowered a bit.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 15th March 2003, 11:33 AM   #6
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default My sugestions...
Hi hugobross!!!
Here is my sugestions:
-Change the Zener to two small sinal diodes (aka 1N4148) ...less noise!...as the LTP current is 2,5mA , R17 must be changed to 240 Ohm!
-Delete R 23 (pot) and conecte directely.the base of T14 to the diodes and the base of T13...then choose R 20 for 0'6 volts across it, with a current that you want for the Vas stage...after that, R1 must have a value to put +- 2 mA across the 4148 diodes...
The base of a CCS transistor like to see a stif voltage source at the base and the pot(R23) was kiling this!
- Put a 4'7 k resistor betwen the colector of T13 and the point of union of R7/R8...it will isolate the LTP from the nonlinear output capacitance of T13...
-Put a 100 Ohms resistor betwen the emitors of the drivers..
Tell me what you think!
Ps:some degeneration in the emitor of the lower Vas transistor (BD241 C) will be also a good idea..but R4 must be recalculated!
One more point...What is it for R 29 (22K)?
Jorge
Old 18th March 2003, 04:28 PM   #7
Thanks,
Circlotron, good point! What about placing a pot over the excisting zener??
Tube dude, I don't know if normal diodes have better noise figures than zeners; but I guess you're right! It's no big deal to change that!
I like this adjustable current source, and I'm not sure about deleting the pot.
A 100 ohm resistor between the driver emitters is a good idea
In which way do you mean non-lineair?? I don't know if this non-lineair capacitance will affect the working of the LTP. The current through T13 is constant, right?
R29 is for bridging two of this amps, didn't use it by now.
euh, what do you mean with this one?? my english isn't that good I guess.
thanks,
HB.
Old 18th March 2003, 09:06 PM   #8
Tube_Dude's Avatar
Default To Hugo...
zeners produce "white noise"...zeners are one of the elecronics components that produce more broadband noise...
The efect is even greater then when you take out the muting transistors in a CD player...the logical is about the same...and in a CD player the impedance is lower...the efect in the LTP is greater!!
To put a emiter resistor in this transistor(BD241C)....
Jorge
Old 19th March 2003, 10:33 PM   #9
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Looks good
Assuming you can't (or don't want to redesign the PCB ....
Don't you need a cut in the "ground loop" around the perimeter of the pcb?
Maybe I should rephrase that: I'd make a cut through that ring around the circuit.
Old 22nd May 2003, 05:40 PM   #10
still didn't finished the amp completely
no time, no money
best regards,
HB.
just found back a quick drawn schematic of my ampHide this!Advertise here!
Hey...found the Acoustat TNT-200 schematic! (and TNP preamp) KBK Solid State 69 21st June 2015 11:04 PM
Found Meixing Amp schematic, sorta, would like some feedback pjpoes Tubes / Valves 3 4th March 2007 04:22 PM
Preamp Schematic I Found On The Web. Feed Back Wanted. LJOE1969 Instruments and Amps 5 29th August 2005 05:53 PM
A few quick question before glueing the back of my enclosures mr_push_pull Multi-Way 5 19th November 2004 04:06 AM
300B pp schematic found, what about it? jogas Tubes / Valves 24 28th August 2004 01:15 AM
Copyright ©1999-2017 diyAudio
