I have built up the P88 preamp. http://sound.westhost.com/project88.htm I'm using a 100K Ladder type Step Attenuator. The issue I'm having is when I turn the step attentuator to -33dB(which is 100K and 2.2K), the output goes into oscillation. It does this for the next few steps and then goes back to normal. This is with a 1VP-P sine wave on the input. The other levels are just fine on the step attenuator until I reach the 100K/2.2K. I have double checked and measured the step attentuator, all values are correct. In the P88 notes, it mentions if you set the P88 2nd stage to 0dB, it may oscillate. I have the switch set to 1 On, 3-4OFF, which should be 4.44dB for both channels. Should the Op amp be slightly warm to the touch? Any ideas? Thanks. |
#2 |
which chips are you useing?
#3 |
OPA2134's
#4 |
They should be stable at unity gain.... why not add a tiny bit of gain on the second stage....?
#5 |
how/where have you coupled the attenuator? Before the amp or after the amp? Or is there a way to tap into the PCB between the two active stages?
regards Andrew T. |
#6 | |
Any audio ccts I have seen usually have a cap between the inverting input feedback resistor and ground.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#7 |
I will increase the 2nd stage gain and see if it goes away.
The step attenuator is between the stages. The pic shown is how I have it wired. It is cap coupled. Thanks :-) |
#8 |
this is what I get at the 100K/2.2K setting.
top is input, bottom is output |
#9 | |
Any DC offset from the first stage will be amplified and you could end up with a serious offset.
#10 |
are two of the switches 1 to 4 always closed? Each active stage becomes an opamp follower (gain 0dB) if the feedback switch is open. I don't like that. What happens to your oscillation if you change the switch positions? I'm guessing that R5 & R6 are remnants from the linear pots ESP used. If you have a logarithmic attenuator then R6 can be open circuit or 100k. 100k pot feeding Zin=15k is not usually recommended. R5 could be much lower, maybe 100r like the second stage. There appears to be no RF filtering at any of the inputs.
regards Andrew T. |
| img pa-amp issue | gruni | Solid State | 11 | 12th August 2009 10:22 AM |
| Hum issue | e_fortier | Class D | 6 | 3rd March 2009 02:42 AM |
| Help With TLB / Amp Issue | Forster | Multi-Way | 0 | 2nd May 2007 07:51 PM |
| Nuuk Buffered Passive Preamp Issue | filholder | Chip Amps | 51 | 22nd November 2005 09:00 PM |
| Amp and Sub issue | AudioMistake | Car Audio | 1 | 26th June 2005 08:59 PM |
| Page generated in 0.11672 seconds (81.35% PHP - 18.65% MySQL) with 11 queries |
