Old 9th June 2008, 02:46 AM   #1
Default HIGH Fidelity-amp discussion
hi,
I am just wondering about "HIGH Fidelity amp with mid watts by using 8 pair of 2sc5200 and watts can be 100 to 150rms...making class AB amp. Is it possible to make?
As I have seen some very expensive amp using many power transistors to produce nice strong sound but in mid output watts. I have found that low fidelity amp doesn’t produce strong life sound.
I am not an engineer as I said earlier. I might be wrong but I want to understand.
Thank you
michael
Old 9th June 2008, 06:19 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: HIGH Fidelity-amp discussion
Originally posted by space2000
hi,
by using 8 pair of 2SC5200 and watts can be 100 to 150 Wrms...making class AB amp. Is it possible to make?
Thank you
michael
'mid watts'
maybe like 100-150 Watts into 4 Ohm or 8 Ohm speakers
'using 8 pair of 2SC5200'
Now 8 Pairs, is same as 8x2 = 16 Transistors 2 SC5200.
What is not clear, is if you ONLY will use NPN 2SC5200
... or if you mean PNP, 2SA1943, too
If you only want to use NPN transistors (only 2SC5200),
you should search forum for
'Quasi' or
'N-Channel' ... amplifier
Because this is what we normally call amplifiers with only NPN output devices.
This is one way, to try to make Truly Complementry Amplifier
Because there is No case, of perfect complementary NPN + PNP pairs, not yet
regars, lineup
lineup
Old 9th June 2008, 06:34 AM   #3
yes have to use pnp and npn, it is 2sc5200 4pcs and 2sa1943 4 pcs, 100 to 150 watts into 8ohms.
thanks for your comments.
Old 9th June 2008, 06:42 AM   #4
ttan98 is offline ttan98  Australia
see this site:
http://sound.westhost.com/project68.htm
change the o/p transistors to 2sc5200 & 2sc1943.
Old 9th June 2008, 08:49 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
It's not all about the output transistors if you’re shooting for "high performance". The driving circuits (input, VAS, ect) are really the determining factor, IMHO. You could make a great amplifier using "cheap" outputs, if you have no objection to complexity. With 8 pair of 2SC5200/2SA1943 for 100Wrms class A is not out of the picture, eh?
All the trouble I've ever been in started out as fun......
Old 9th June 2008, 09:23 AM   #6
thats why i want to know what is really works for high quality sound from amp. thanks CBS240....
i ever heard from some amp quality sound, i don't know watts are there. may be not much but sound so nice and the bass is very tight with deep.....trble too sweet...don't know what is there in side...ha...ha....
thanks again.
The Death of High Fidelity chascode Everything Else 21 4th May 2008 02:31 PM
The death of high fidelity fernando_g Music 13 8th January 2008 06:21 PM
Nanoelectronics and High Fidelity amsci99 Digital Source 1 8th December 2007 04:31 PM
Nutshell High Fidelity Cloth Ears Multi-Way 2 2nd April 2007 10:04 PM
I coined the phrase HIGH VIVIDITY, to differentiate our amps from High Fidelity ones vax9000 Tubes / Valves 8 31st October 2006 02:10 AM
Page generated in 0.08987 seconds (85.61% PHP - 14.39% MySQL) with 10 queries
