Hello,
I’m currently working with a Denon AVR-486 receiver. I have already found out what’s ailing it, but I’m having trouble identifying two shorted surface mount diodes which are connected in series with each other in the output section of the unit. The outputs being used are Sanken 2SB1560 and 2SD2390 and a 2SD947F in between as a driver. The schematic designation numbers of the diodes are D101 and ZD102 (zener diode) below is a pic of of the two diodes. The zener is marked 82 and the other diode T4. I’ve already looked at different things that supposedly decode the markings but the results were so much all over the map they were no help with identifying them. I just wanted to see if anyone has the service data on this unit to find out what exactly I’m going to need for replacements. Thanks |
| diodes | changsecho | Solid State | 1 | 31st May 2008 04:32 PM |
| Old Diodes | betweenpie | Tubes / Valves | 2 | 3rd June 2007 04:06 PM |
| Diodes | carlmart | Chip Amps | 0 | 4th March 2004 11:50 AM |
| what to look for - diodes | Raj1 | Parts | 1 | 18th September 2003 01:44 AM |
| Page generated in 0.06293 seconds (64.78% PHP - 35.22% MySQL) with 11 queries |
