I am cleaning my office and found my stash of "ancient" reverse engineering projects. This is the BB3554, it was near the top in its day ~1979. These product are now obsolete and there is no longer any IP interest. I thought some of you might enjoy seeing where folks were back then, in some cases not too far off from were things are now. This was in a BIG 12 pin TO-3 can (note the BeO substrate).
2012, our time is running out. |
#2 |
Was this a hybrid circuit?
se |
#3 | |
#4 |
Wow!!!!
I used the BB3554 in 1982, for squirell-cage 63kA shunt active compensation. I got 2MHz bandwidth from that combo. The shunt used for development of SF6 HV circuit breakers, measurements of post-arc currents after zero (interruption). I still have documentation and scientific report. |
#5 |
No kidding, here it is:
(P.S.: If I was to write my professional memories, it would be probably more juicy than those of John ... |
#6 |
The shunt. In the deep dark times of iron curtain, I used Tek556 and Tek7844 dual beam scopes here.
#7 |
Further "classiscs"
#8 |
Hello,
Thanks for posting the schematic Scott. I was actually looking of using a jfet input cascode that is bootstrapped for a amp circuit like this chip. I think that Q3 and Q4 cascode jfets must have higher Idss than the input Jfets Q1 and Q2 and higher Vp. This is going by some other jfet self biasing circuits I have seen though I don't know about other pre requisites. Just out of interest does anyone have any references or experience with this arrangement ? Thanks |
#9 | |
Tomorrow I will post the most horrifying schematic I found.
#10 |
Datasheet is easily found by google, the Maxim part.
| Classic 16.0 | Lowrider | Tubes / Valves | 38 | 6th August 2008 08:15 AM |
| The classic proac xover schematic | lt cdr data | Multi-Way | 0 | 22nd June 2005 09:44 PM |
| schematic for audio research classic 120 amps? | audiomatic | Tubes / Valves | 5 | 3rd May 2004 04:25 PM |
| Classic DIY articles | Fred Dieckmann | Solid State | 1 | 24th October 2003 11:03 PM |
| Page generated in 0.10361 seconds (77.06% PHP - 22.94% MySQL) with 11 queries |
