I just finished my P3A. I'm very impressed with the sound- I really love this amp. Since I'm at school and was working in an electronics lab, the only source I had to test it with was a portable CD player- everything sounded great so I brought the amp back to my room and just tried playing a DVD through my laptop. The sound was terrible- loud, distorted and ringing. I thought this might be a ground loop so I tried floating the ground on the amp- it solved the problem and everything sounded perfect once again.
My connections are as follows: (I have an aluminum chassis)- the earth ground comes in through a filtered IEC socket and is immediately grounded to the chassis. The signal comes in through RCA jacks and is grounded to the chassis. The binding posts are connected directly to board which, in turn, is grounded to the chassis. The hot and neutral enter 2 transformers and the center tap of each is grounded to the chassis. I would like to eliminate the ground loops, but I want to find a safe way of doing it. Simply floating the ground sounds very dangerous-- any advice on a better way to eliminate the ground loops safely with this design? Thanks. Brian |
#2 |
Just had a though- if I eliminated the earth ground and just fused the hot and neutral would that be safe enough?
#3 |
Not really. The ground is for faults. If you lost the neutral (and weren't double insulated), your chassis could become energized. Bad news.
Try doing the ground lift circuit using a bridge rectifier that's on the elliot site. It introduces some impedance to the ground path, but the bridge allows fault currents to flow to safety ground.
It's cheaper than a movie, and there's free coffee. |
#4 |
Hi!
Do yourself a favour, build a grounding star point, isolated from the chassis. Connect earth to chassis (you already did that), all ground connections (from supply caps, amplifier, maybe input signals - if you don't wire them to amp) go to the star point. Then run a single connection from star ground to chassis with a 0.47 uF (rated at least your mains AC voltage, to be on the safe side take a little bit more) polyester capacitor, maybe bypassing a 100 ohms resistor. And / or try using something like the current breaker circuit from ESP website. That got rid of all my ground loop probs on my End Millenium amp... Hope this help, Arndt
************************ A Sacrifice For Freedom |
#5 |
Thanks for the replies- I'll give that a shot.
With the two separate grounds- why do they need to be connected at all? How come I couldn't just earth ground the chassis and then ground the powersupply and all signals in some other place and just leave it alone? Brian |
#6 |
Faults again. If your rectifier fails with a short, the ground would again be energized.
Personally I'd definitely have a resistor between the grounds rather than just a cap if you go that route. I think Elliot uses 10 Ohms 20W. You'd want low enough impedance and high enough power rating to make sure any fault currents are shunted through earth.
| Ground loops and containment | jneutron | Parts | 49 | 18th February 2011 02:28 PM |
| Ground loops, speaker hum and buz | steevo | Solid State | 15 | 31st October 2008 09:58 PM |
| UK laws - dealing with ground loops? | johnm | Power Supplies | 9 | 4th August 2008 03:05 PM |
| Safety question concerning ground loops | derMichi | Chip Amps | 5 | 9th June 2006 08:31 AM |
| Earth/Ground Loops | JohnClark | Tubes / Valves | 2 | 14th November 2001 12:49 AM |
| Page generated in 0.08993 seconds (82.36% PHP - 17.64% MySQL) with 10 queries |
