Old 3rd June 2008, 11:04 PM   #1
Exclamation help building an amp of sorts?
Hey guys, I have a 400watt compression horn driver and I need to build something to drive it to a volume of about human voice. I was thinking it to be along the lines of input (for my guitar), volume, and output (for driver). Basically an amp with no speaker just an out put.
(I guess this would be called an amp head? Idk)
Old 3rd June 2008, 11:31 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
What is the senitvity of your intended speaker / horn?
To get to the level of a human voice does not take much power / watts.
For a normal sensitivity speaker ( ~ 88-90 dB SPL )
probably only 0.1 Watt or so.
A speaker with 90dB sensitivity puts out 90dB .. at 1 Watt ( 2.83Vrms output into 8 Ohm ).
And 90dB is LOOOUUUD!!!
lineup
Old 4th June 2008, 12:00 AM   #3
104 dB SPL 1W/1M
8 Ohm Impedance
Old 4th June 2008, 12:00 AM   #4
nigelwright7557's Avatar
Just buy a cheap amp off ebay or from an online store.
Anything below 50 watts would do the job fine with plenty of overhead.
You could get away with less watts but I find you lose some transient response with lower wattages.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 4th June 2008, 12:37 AM   #5
unclejed613's Avatar
a horn that efficient only needs 1 watt or less for the application you're describing. 50 watts would give you about 121db SPL. that's 104db + 17db (for 50 watts. i took 100watts=20db, subtract 3db (for cutting in half to 50 watts)=17db.
121db is just above the threshold of pain. if you're simulating a normal human speaking voice, go with a good 5 watt amp.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 4th June 2008, 12:42 AM   #6
Yes but thats going full whack, in which case your transients have long since started clipping.
In practice real music has a huge dynamic range compared to testing the amp with a sine wave.
Old 4th June 2008, 01:39 AM   #7
Might want to try a mono chip-amp.
Old 8th June 2008, 11:45 PM   #8
My line 6 spider III 30w amp can drive the horn driver alone at a pretty decent volume, however, since I'm using it in a talkbox and it has to run through about 10 ft of vinyl tubing by the time it reaches my mouth its so quiet I can barely hear it.
But I found my dads old JVC JR-S300 Mark II stereo receiver and when I plug it up to that and turn on the radio it gets about the right volume.
I don't know what the output wattage is on the JVC but my dad seems to think its around 50W. I has some information on the back but I couldn't find a clearly marked output wattage.
Old 9th June 2008, 12:21 AM   #9
Banned
Sorry, this is a horn driver without a horn being employed in an unconventional fashion?
Normally a horn driver actually drives an exponential horn which provides an impedance match to the atmosphere.
Otherwise the apparent volume produced by the driver will be very small. I think you'll get a lot of distortion too, because of the failure to accoustically load the driver and the reflections at the mismatch.
Does the tube connect directly to the driver or is there a change in diameter?
Anyway, please clarify...
w
Old 9th June 2008, 12:36 AM   #10
No. I have two plumbing parts connect to the open hole in my compression horn driver to the 10ft long 1/2" OD x 3/8" ID Vinyl tubing. Also I've been messing around with it and if my dad is right, and the output is around 50W (I'll know soon enough I've emailed JVC), than I may even want a little more wattage. Maybe something around 60-70 watts or an amp head with a peak of 100w and a volume control so I can get the desired volume.
FYI: Dynaco ST 400 (A reveiw of sorts) The Donk! Solid State 4 16th March 2008 12:11 PM
Should I even consider building wad06 Subwoofers 25 28th January 2005 02:52 AM
GC's in all sorts of boxes.... JDeV Chip Amps 1 11th June 2003 08:26 PM
Water as a heat tank of sorts PaulHilgeman Parts 7 2nd May 2003 02:30 AM
Page generated in 0.10121 seconds (78.97% PHP - 21.03% MySQL) with 10 queries
