Hello, Can anyone tell me why the Meridian MCD has a On/Standby switch. I find it a little irritating to have to leave it on standby all day, when i'm using other gear plugged in to the same socket. Can I rewire the switch. I wondered if it needed to warm up to operate well or if there was an intention to supply a remote??. Also anyone have any idea where I can download the manual?? This is the best cd player iv'e ever heard and it's donkeys years old! Thank you for any help. Barry
#2 | |
There is plenty of info if you google it. Unless it has valves I dont understand why they have a standby switch unless it is to save the laser and/or motors. The info says 1984 so I suspect its something to do with the laser. I believe the lasers dont last as long if they are constantly powered up.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Hi Nigel, thanks for your help. Phillips, I beleive, were using the same laser assy in there CD100 and CD101 and they never had standby. About the only info I can find on google is the stereophile review. Thanks. Barry
#4 |
Magneto the Gravity Man
Hey !
How come you are using my avatar? Get your own! |
#5 |
Hi, I found this one on google, but if you can answer my question I will change it!!! Can't be fairer than that boyo!!! Why did Meridian put a standby switch on the MCD. OK, you have three minutes starting now. Greetings Barry
#6 |
It's on google as Google search found it on DIY Audio It's on diyaudio 'cause I did the original animated gif for my avatar. |
#7 |
Sorted.
#8 |
Bet you got that off Google , too !
It's been used by Zero Cool for many months !! |
#9 |
This one said it was FREE for anyone. Why don't you make me one??
#10 |
Hi, my first post. I've repaired a Meridian MCD and it sounds wonderful, but there is a loud switch-off thump when I disconnect the power.
I downloaded the MCD user manual from hifiengine and it says "If you wish to unplug the MCD during an extended period of non-use, be sure to disconnect the rest of the system before disconnecting the mains plug.". So the switch-off thump appears to be a feature, which is unfortunate, because it is otherwise an excellent player. Does anyone have a schematic of the MCD analog output stage? I have a Marantz CD63 service manual, but the MCD is significantly different and has no muting relays. |
| My Meridian 565 mod | PWatts | Digital Source | 1 | 5th January 2012 07:55 AM |
| Meridian 508-20 | Richard984 | Digital Source | 14 | 2nd February 2008 09:49 AM |
| Meridian 596/24 bit dvd vs Meridian 508/bit | Sclalars | Digital Source | 0 | 8th February 2006 06:48 PM |
| A2I on Meridian 566 | FaZ72 | Digital Source | 0 | 5th April 2004 02:28 PM |
| Meridian 602 | Super | Everything Else | 1 | 12th August 2001 02:43 AM |
| Page generated in 0.09600 seconds (78.05% PHP - 21.95% MySQL) with 10 queries |
