active cable shield driver in a phono amp -- does it make sense (noise- or sonicswise
Old 1st June 2008, 09:53 AM   #1
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Default active cable shield driver in a phono amp -- does it make sense (noise- or sonicswise
in some Neumann phono pres there are active shield drivers that reroute a part of signal back to the cable shield (between pickup and pre). Has someone actually tried this with good results?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 25th November 2016, 03:51 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
Bump - I'm also curious about this ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 26th November 2016, 12:09 AM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
It's something that they do in instrumentation when dealing with very small signals in harsh electrical environments.
But it's in extremely high impedance circuits and phono stages are low to very low impedance.
Keithley Instruments might still have some notes on 'guarding'.
Kevin
Old 26th November 2016, 02:20 AM   #4
PRR is offline PRR  United States
PRR's Avatar
In theory you can negate some of the cable capacitance which loads-down the top end of the cartridge response. However such carts are *wound* assuming some capacitance. Typically 3 feet of cable and the grid of a 12AX7. Blindly nulling the expected cable cap may not be best. The 3 feet was very standard in days of tubes, had to reach from the turntable to the adjacent amp chassis. But with transistors we can put the preamp almost anywhere, and then drive any length of line.
You would think it "could" improve shielding. I have doubts. But the cartridge itself is always going to pick-up crap from the room. It can't be 101% shielded, the needle and pins have to stick out. Happy hi-fi means finding a happy (quiet, solid) place for the turntable.
I have done something like that for an in-turntable preamp. Mostly for compactness and circuit simplicity. (There was DC on the cart, but not through it.) I did not find any sonic revelation I could pin on this trick.
Old 26th November 2016, 01:37 PM   #5
The Keithley 'Low Level Measurement' handbook. Start with Guarding on page 2-15.
http://www.tek.com/sites/tek.com/fil...ndbook_7Ed.pdf
Kevin
active cable shield driver in a phono amp -- does it make sense (noise- or sonicswiseHide this!Advertise here!
Does USB->I2S make sense ? percy Digital Line Level 20 24th March 2009 01:23 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Have annoying noise?... want a diy shield... try this one. destroyer X Solid State 17 8th October 2005 10:52 AM
does this make sense? nosegoblin Solid State 9 14th February 2004 02:19 PM
Cable shield grounding Prune Parts 1 20th December 2003 01:28 AM
Copyright ©1999-2017 diyAudio
