Old 30th May 2008, 02:51 PM   #1
rfarn is offline rfarn  United States
Default 1 source to 2 amps
What is the PROPER way to attach 1 preamp to 2 or more amps? The preamp only has 1 output. Currently they are just split with a Y cord.
Old 30th May 2008, 03:10 PM   #2
good enough.
But, do check that both power amps have DC blocking caps on their inputs.
regards Andrew T.
Old 31st May 2008, 02:59 PM   #3
Andrew,
How do I tell if they do have DC blocking caps? Will this work for more than 2? At what point would I have to worry about signal loss, resistance, etc?
Bob
Old 31st May 2008, 05:32 PM   #4
check the spec or open it up to see if the blocking cap (one on each channel) is fitted.
Let's suppose your pre has an output impedance of 500ohms and that is is capable of driving a 10k load.
Now your power amps have an input impedance of, say, 22kohms.
Two in parallel = 11kohms and is above the minimum load impedance for the pre.
Three in parallel would be 7k3, below specified minimum load impedance and not suitable.
Read your specs and find out what each are.
regards Andrew T.
Old 31st May 2008, 08:59 PM   #5
nigelwright7557's Avatar
Much more than 2 and you will need a splitter/buffer.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st May 2008, 09:24 PM   #6
Take a look to this
La vida es bella.
Old 1st June 2008, 12:09 AM   #7
Why a gain of 10?
Old 1st June 2008, 12:17 AM   #8
Originally posted by whoandcar
Why a gain of 10?
Its also got a 10 second power up on the 100uF..........
I dont know why the 100uF is connected to half VCC.
It only needs none inverting input connected to half VCC
Old 1st June 2008, 08:40 AM   #9
forget post 6.
check your specifications first.
regards Andrew T.
Spare parts source for SWR bass amps lundborg Instruments and Amps 5 19th July 2008 11:38 AM
Sound card as source, two different monoblock amps. beerman Chip Amps 4 17th March 2007 07:05 PM
Current Source Amps zenmasterbrian Subwoofers 36 29th September 2006 06:38 AM
Perfect Speaker for Current Source Amps? NV&H Pass Labs 23 30th January 2006 12:12 PM
Current source amps and shorting rings joe carrow Multi-Way 2 13th December 2004 10:18 AM
Page generated in 0.09089 seconds (76.52% PHP - 23.48% MySQL) with 11 queries
