diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Anyone have experience with this pp linear hexfet amp? (http://www.diyaudio.com/forums/solid-state/12402-experience-pp-linear-hexfet-amp.html)
qwad 13th March 2003 04:58 PM
Hi all, while surfing the net I came across this interesting little circuit at, http:// home eunet cz/rysanek/pdf/irf-fet-amp.pdf the circuit is quite straight forward and easy to build and set up it uses2 IRF COMPLIMENTARY HEXFETS (iRF 532& 9532)IN A COMPLIMENTARY PP CONFIG PUTTING OUT 60w into4 ohm or 32w into 8, I would be interested in your valued opinions of this little circuit:idea: :scratch:
regards to all,
tamás
JBL 13th March 2003 07:13 PM
Your link is mispelled.
qwad 13th March 2003 11:32 PM
OOps!
:o Sorry, there seems to be a bit more to it that than I was led to beleive found the right address on another page:dodgy: so try this , hope it works...http://webferret search.com/click? s...et% 2Damp%Epdf
:bulb: hope this takes you there
Regards, TJB
Circlotron 14th March 2003 01:07 AM
First address fixed.
http://home.eunet.cz/rysanek/pdf/irf-fet-amp.pdf
JBL 14th March 2003 01:32 AM
This is the application note from IRF about using their products for linear audio amp. Never built it and never heard of someone who built it either.
But IMHO just by looking to the circuit this is a very basic circuit and could be better in some aspect so I don't recommend it.
(BTW the original is at www.irf.com in the application note section)
AKSA 14th March 2003 09:55 AM
Good circuit.
Most of the difficult design issues addressed, well documented, simple.
Excellent start point for 'mosfet' sound.
Try it. You won't be disappointed.
Hugh
UrSv 14th March 2003 11:50 AM
Originally posted by AKSA
Good circuit.
Hugh
I think also since this amplifier has been discussed in the forum quite a few times one could probably find something useful in:
http://www.diyaudio.com/forums/showt...&threadid=2236
Resources saved on this page: MySQL 18.75%
