Old 29th May 2008, 11:29 PM   #1
maxpou is offline maxpou  Canada
maxpou's Avatar
Default Power Supply for jfet line Stage
Hi all,
I want to try a new power supply for my new line stage, but i'm not sure if i have enough filtration in location C5, 6, 7 and 8. My new line stage is in this thread.
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS?
thank you! Maxpou
Old 29th May 2008, 11:58 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
enough
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 30th May 2008, 12:58 AM   #3
maxpou's Avatar
sorry for my bad english, but i mean if i need more filtration or it's ok, because i found a 1000uF ROE EKO and i think it's a good capacitors? Thank you! Maxpou
Old 30th May 2008, 01:02 AM   #4
Zen Mod's Avatar
I meant - it's enough with that amount of capacity you show on schematic ;
of course - more is always better
Old 30th May 2008, 01:07 PM   #5
what's the quiescent and peak current draw?
I'm guessing around 20mA and 30mApk.
If as little as this, then 1mF is just fine.
regards Andrew T.
Old 31st May 2008, 07:05 PM   #6
maxpou's Avatar
Hi Guys,
thank you for replys, this is my PCB. comment please? Maxpou
Old 31st May 2008, 08:55 PM   #7
nigelwright7557's Avatar
Hi Guys,
More copper !!!
Connect GND to a power plane that fills in all the unused copper.
It decreses the impedance of the tracks and also uses less etching chemicals.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st May 2008, 11:42 PM   #8
A) the two AC inpouts should be farther apart to ensure easy soldering with no possibility of shorts. The AC "wires could be made larger (i.e. beefier).
B) The ground "wire" runs down the center. What would be ideal is for every component to have a wire directly to the common point of all grounds (star patern). However, the easy fix is to change this 'wire' into a solid layer filling all available space in the cernter with a couple of cutouts for the components that intrude on this 'bus'.
C) The V+ and V- "wires" should be beefed up similar to those of the ground system, but section at a time. For example, the wire connecting components around C6 should be approximately a parallelogram.
D) I, personally, would be tempted to gun the grounding point out and under the diodes and capacitors near the AC inputs such that the whole AC part of the system is isolated with a ground strap. Thus, the wire from point PGND is extended to the left and then splits and runs under the Ds and Cs at least to the edge (top/bottom) of the board. Thus isolating the AC section.
E) I would be tempted to rotate R3, R4 90 degrees and move r5, r6 to the right allowing the zerars to move outwards, simplifying the route in the mid section of the supply.
Old 1st June 2008, 08:37 AM   #9
Mitch's comment B must be adhered to or at least the dirty grounds from the smoothing end MUST have a separate route to the star ground AT THE OUTPUT.
I would recommend that the regulator ground also has a separate route. That makes 5 legs to the star on the PCB side and a further leg for the output side.
I think a ground star will perform better than a ground plane at keeping the dirty charging pulses out of the clean grounds that determine the output ripple.
regards Andrew T.
Old 1st June 2008, 01:48 PM   #10
jackinnj's Avatar
Shouldn't the 1N4148's be reversed?
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 08:30 AM
Alternative filament supply for 01A line stage arnoldc Tubes / Valves 3 18th April 2007 11:57 PM
help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er jarthel Tubes / Valves 9 30th May 2006 07:47 AM
power supply for phono stage carlos671 Parts 0 5th February 2006 10:55 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Page generated in 0.09391 seconds (86.36% PHP - 13.64% MySQL) with 11 queries
