Help me with my JFET / BJT design
Old 13th March 2003, 02:32 PM   #1
RichardJones is offline RichardJones
Default Help me with my JFET / BJT design
OK... I tried to attach an image.. but its in emf? format.
Simply put... the pre-amp was simulated with 2N3819's and BC547's.
It has a cascode 2N3819 with a 560 ohm source resistor and a 10K drain resistor.
Running from a +36v supply... that places the upper 2N3819 drain at around 18v.
This is taken from this point into 3 paralleled BC547 emitter followers with a common 270 ohm resistor.
Output is taken from this point via a 1uf cap and a 10K load resistor.
Simulating the circuit... I get 0.0001% THD with 10v peak output at 1Khz.... but at 10Khz get 3.53% THD...
Why the huge difference?
Should I be running more current in the cascode?
btw... I need a voltage gain of 10.
Thanks!!!!
Old 13th March 2003, 10:58 PM   #2
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Simulations
Hi Richard
First of all it would help with a schmatic
The THD simulation is difficult, since it's based on samples, and a FFT (Fast fourier transform) The problem is problably the simulator and not your amp.
Also the THD needs a center freq to do the calculations. What program do you use?
My experience is that simulations are less than perfect regarding THD, but a nice tool to make sure all your DC levels are right.
\Jens
Old 13th March 2003, 11:10 PM   #3
mlloyd1 is online now mlloyd1  United States
mlloyd1's Avatar
yeah, we need a schematic.
and I think most of us have come to the conclusion that distortion numbers on a simulator are about as close to worthless as you can get. there was at least one thread on this a while back.
sorry
mlloyd1
Old 14th March 2003, 02:00 PM   #4
Default schematic?
I am using a SIMetrix demo software.
Ahh... I think I figured it out:
Old 14th March 2003, 02:30 PM   #5
jam is offline jam  United States
jam's Avatar
What happens if you replace R4 with a current source?
Jam
Old 14th March 2003, 02:39 PM   #6
Default Advantage?
The output darlington's don't really add a lot to THD I think... so what would be the advantage?
Would it be better to put one on the Source of the cascode?
Thanks!
Old 14th March 2003, 02:52 PM   #7
jam's Avatar
Possibly,
Why don't you try both and report your results.
Jam
Old 14th March 2003, 02:55 PM   #8
Default split supply
oh... well since the source of the FETS are about 1v above ground.
And btw I changed the drain resistor to 12K and the source to 680. Better symmetrical clipping...
I would have to go with a split supply to build a CCS for the source of the input FETS.
I could try a CCS on the output NPN....
Old 14th March 2003, 02:59 PM   #9
Default CCS on output
Remember that I am simulating all of this... and don't have anything built..
the CCS didn't change anything wrt the 560 ohm resistor.
the simulated distortion is dominated by the input FETS.
Old 14th March 2003, 03:47 PM   #10
jam's Avatar
I suppose you could cap couple the input and use a voltage divider to pull up the gate of the fet to avoid building a split supply.
Jam
Help me with my JFET / BJT designHide this!Advertise here!
Borbely JFET design happy_guy Solid State 43 18th November 2008 07:35 AM
JFET CS design, how? (and possible SPICE oddity) StefanTH Solid State 4 23rd October 2008 11:24 AM
JFET aleph- design comments please nobody special Pass Labs 41 4th September 2006 03:05 PM
headphone amp similar to Borbely jfet design sunrise Headphone Systems 21 6th October 2005 05:02 AM
Simple amp design JFET and follower RichJones Solid State 9 8th September 2003 03:24 PM
