Old 26th May 2008, 03:13 PM   #1
bulgin is offline bulgin  South Africa
Default Did I waste my bucks?
Hi All
I found a Scott 410A integrated amp at a 2nd hand store today, Price and condition is reasonable. I had the store hookup a tuner and a pr of speakers and that seems to work and the volume pot and other controls seem fine.
I'm trying to find some more info but came across a comment elsewhere about it being a pretty mediocre piece of kit.
The price paid was around 40 dollars US and there are no scuff marks or scratches. Only dirty.
Does anyone here own this amp and how do you rate it? Or did I waste my money?
Any info much appreciated.
Thks
bulgin
Old 26th May 2008, 04:02 PM   #2
es44 is offline es44  Denmark
es44's Avatar
Well, if nothing else, then you have bought yourself a cheap case for a DIY-amp.
Such cases are hard to find, at least where i live.
Best regards
Ebbe
Old 26th May 2008, 05:33 PM   #3
Okie, Dokie
I'll grin an bear it
bulgin
Old 26th May 2008, 08:17 PM   #4
es44's Avatar
I don't know what transformer is in such a Scott, but if you are lucky, then it will fit the DXII amp, that your fellow countryman Nordic made PCB's for. It's a very cheap amp to build, and the reports so far sounds as if it's a one of a kind.
That way you would have a nice case, and a great amp quite cheap.
I'm sorry to say, that i haven't finished mine yet, too many projects at one time . Oh yeah, and i need an empty case.
Best regards
Ebbe
Old 26th May 2008, 09:15 PM   #5
Thanks, Ebbe
Nordic's sure to see this when he peeks here. I haven't actually handed over the bucks as I didn't have my car with me. The amp is reserved for me until tomorrow and that case sure looks impressive with the two meters on the face.
Cheers
bulgin
Old 27th May 2008, 04:55 AM   #6
es44's Avatar
Oh, you already did order a set, i should have seen that one coming.
You make me curious, i would love to see a picture of that Scott, it sounds like you have had "luck with your bad luck" as we say here.
Maybe you even get your amp finished before me.
Best regards
Ebbe
Old 27th May 2008, 09:36 AM   #7
Hello Ebbe
I'll go pick up the Scott later today. I'm busy making some needles right now. When there's a chance, I'll clean it up and post pics of the inside and outside.
It's been a bit frustrating as I've been unable to find any specs at all, looking in many places.
bulgin
Old 27th May 2008, 10:04 AM   #8
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Did I waste my bucks?
Originally posted by bulgin
Hello Ebbe
There are Service Manuals (usually with schematic & all details)
for
Scott Integrated Amplifier 410A
if you think you can afford the cost $22.32 dollars
http://www.manuals-in-pdf.com/410A-p-336464.html
Here is a list of all Scott manuals, at that site:
http://www.scott.manuals-in-pdf.com/scott-c-60.html
Whatever you do with that amplifier, at that price it was good to buy.
Either to do some interesting diy rebuild/upgrade/tweaking.
Or for re-use of case + trafo + heatsinks and whatever more.
lineup - friendly hifi regards
lineup
Old 27th May 2008, 11:30 AM   #9
Dan2 is offline Dan2  South Africa
the service manual will cost almost the same as your amp!!
i bought a really crappy amp for R600 about 2 yrs ago
it sounded fine in the shop but when i got home and ran 4ohm speakers on it, there was NASTY crossover distortion (at low volume)
i ran 6ohm speakers on it for a while - that sounded ok-ish
now i have bridged it and run it with a car sub - just waiting for it to die then i will use the transformer and build my own amp
Old 29th May 2008, 12:18 AM   #10
Hello Guys
Thanks a lot for your kind replies Well, I brought it home - kept in a black bag until my wife had done her rounds to sniff out what came home ; - and when things calmed-down, I did a bit of cleaning up. I hooked up some speakers and a turntable and for the first 1/2 hour, the 410A sounded a bit lacklustre. Another hour later, things became much better as the ol' gal warmed up.
All controls are quiet and the only thing faulty is the meter lights. I've since seen another similar 410A with rack handles, but this will have to wait until the gutting or makeover...
Cheers all
bulgin
From Bucks County, PA, U.S.A. editorjuno Introductions 3 27th July 2009 05:07 PM
PE sub amp 200W for 99 bucks AJ Bertelson Subwoofers 0 29th December 2003 02:53 PM
Speaker Ideas for 500 bucks jteef Multi-Way 24 28th October 2001 05:17 AM
Page generated in 0.11380 seconds (79.95% PHP - 20.05% MySQL) with 11 queries
