Hi All
I found a Scott 410A integrated amp at a 2nd hand store today, Price and condition is reasonable. I had the store hookup a tuner and a pr of speakers and that seems to work and the volume pot and other controls seem fine.
I'm trying to find some more info but came across a comment elsewhere about it being a pretty mediocre piece of kit.
The price paid was around 40 dollars US and there are no scuff marks or scratches. Only dirty.
Does anyone here own this amp and how do you rate it? Or did I waste my money?
Any info much appreciated.
Thks
bulgin
Thks
bulgin
I don't know what transformer is in such a Scott, but if you are lucky, then it will fit the DXII amp, that your fellow countryman Nordic made PCB's for. It's a very cheap amp to build, and the reports so far sounds as if it's a one of a kind.
That way you would have a nice case, and a great amp quite cheap.
I'm sorry to say, that i haven't finished mine yet, too many projects at one time . Oh yeah, and i need an empty case.
Best regards
Ebbe
Best regards
Ebbe
Hello Ebbe
I'll go pick up the Scott later today. I'm busy making some needles right now. When there's a chance, I'll clean it up and post pics of the inside and outside.
It's been a bit frustrating as I've been unable to find any specs at all, looking in many places.
bulgin
bulgin
bulgin said:Hello Ebbe
There are Service Manuals (usually with schematic & all details)
for
Scott Integrated Amplifier 410A
if you think you can afford the cost $22.32 dollars
http://www.manuals-in-pdf.com/410A-p-336464.html
Here is a list of all Scott manuals, at that site:
http://www.scott.manuals-in-pdf.com/scott-c-60.html
Whatever you do with that amplifier, at that price it was good to buy.
Either to do some interesting diy rebuild/upgrade/tweaking.
Or for re-use of case + trafo + heatsinks and whatever more.
lineup - friendly hifi regards
the service manual will cost almost the same as your amp!!
i bought a really crappy amp for R600 about 2 yrs ago
it sounded fine in the shop but when i got home and ran 4ohm speakers on it, there was NASTY crossover distortion (at low volume)
i ran 6ohm speakers on it for a while - that sounded ok-ish
now i have bridged it and run it with a car sub - just waiting for it to die then i will use the transformer and build my own amp
Hello Guys
Thanks a lot for your kind replies Well, I brought it home - kept in a black bag until my wife had done her rounds to sniff out what came home ; - and when things calmed-down, I did a bit of cleaning up. I hooked up some speakers and a turntable and for the first 1/2 hour, the 410A sounded a bit lacklustre. Another hour later, things became much better as the ol' gal warmed up.
All controls are quiet and the only thing faulty is the meter lights. I've since seen another similar 410A with rack handles, but this will have to wait until the gutting or makeover...
Cheers all
bulgin
Cheers all
bulgin
Hi Nordic
Thanks for the most kind offer. I did the job yesterday. I turned new holders from high temp plastic and after I fitted the new bulbs (2 for 8 bucks ZAR), I let the amp run with the cover off for about 5 hours. Things hardly got lukewarm.
Go well & best wishes
bulgin
bulgin
- Did I waste my bucks?
