new idea for amp
new idea for amp
Old 25th May 2008, 05:33 PM   #1
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
Default new idea for amp
i saw this device advertized in Electronic Design. it's purpose is a piezo element driver, but i think it might have potential as an input/VAS.
http://www.cirrus.com/en/pubs/proDatasheet/PA86U_A1.pdf
any thoughts???
Apex/Cirrus makes a large line of power/high voltage op amps and PWM amps.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 26th May 2008, 12:55 AM   #2
djk is offline djk
djk's Avatar
In the past Apex products were quite expensive.
How much is this thing?
(I sent them a request for quote)
Candidates for the Darwin Award should not read this author.
Old 26th May 2008, 05:55 AM   #3
haven't found out yet. they've been bought by Cirrus Semi, so it's possible their prices may come down a bit...... just part of the mental gymnastics i'm going through with a design.... something looks like a candidate for prototyping, so i investigate it and either it works or it doesn't. it would be nice to find a "universal drop-in" front end for an amp design. if it works it would cure a lot of headaches, but on the other hand, it could cause as many headaches as it cures..... part of my idea is a "universal amplifier" that has a "universal" front end, allowing the basic amp design to be scalable for any output power between 50 and 500 watts, the only real differences being the power supply and output stage. a useable (i.e. stable) front end that can operate at any rail voltage from +/- 50 to +/- 100 V would be a step in the right direction. i have already designed a front end that is basically a high voltage op amp, but needs to be "tweaked" to operate properly at various rail voltages( differences in resistor values, etc...).
Old 26th May 2008, 11:02 AM   #4
Craig405 is offline Craig405  United Kingdom
Craig405's Avatar
I think Marantz do somthing similar with their amps, 'HDAM modules'.
If you didnt already know then it might be of interest
http://images.google.co.uk/imgres?im...%3Den%26sa%3DN
new idea for ampHide this!Advertise here!
Different pre amp idea bartek Solid State 3 25th March 2008 04:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 07:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 09:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 09:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 03:28 PM
