HELP! Rotel RA-1062
HELP! Rotel RA-1062
Old 28th May 2008, 04:25 PM   #21
kchu1377 is offline kchu1377  Hong Kong
Another pic
Old 30th May 2008, 12:42 AM   #22
Hi Michael,
My serial number is 980-4121048. Would appreciate if you can get me a service manual.
Thanks,
Kevin
Old 30th May 2008, 01:52 PM   #23
derguteton is offline derguteton  Germany
Default Service Manual RA-1062
I make your day man,
you can download the manual for five days at :
mmm_dod_sharefx_dod_com
good luck with the repair, it's a really nice device.
Michael
Old 30th May 2008, 11:21 PM   #24
Hi Michael,
Which date was it uploaded? I can't find it.
Thanks,
Kevin
Old 30th May 2008, 11:40 PM   #25
Nordic is offline Nordic  South Africa
Nordic's Avatar
One thing I would do is to disconnect the power supply, if it is possible... replace fuses and see if it can run witout anything connected... It would be a good time to measure some voltages.. a cheap multimeter will do... also google how to do a diode test on transistors...
Now for the part that will save you hours of head scratching, remove transistors one by one, do diode test, resolder if good, mark transistor as tested, do next one...
Old 31st May 2008, 12:16 AM   #26
KP11520 is offline KP11520  United States
KP11520's Avatar
Contact Rotel Tech Support anywhere in the world by email with your model number and they will gladly send you a service manual in .PDF no charge!
They will even sell you whatever parts you can't find anywhere else!
They have excellent customer support!
Good luck!
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 31st May 2008, 12:20 AM   #27
Hi Kevin,
it was uploaded today 30.05.08, nevertheless, get it here:
www.eserviceinfo.bg
Old 31st May 2008, 08:30 AM   #28
I removed all the transistors and did a diode test and found one 2sc3902 and one 2sd1047 blown. I'm still waiting for the parts to arrive.
I noticed there are three opamp in the machine, 2 opa2134pa and 1 opa2604ap. Will it work if I change them to LM4562 or will there be any sound difference? How about changing the capacitors to black gates? Or any suggestion on how to modify this amp?
Thanks,
Kevin
Old 31st May 2008, 11:40 AM   #29
homemodder is offline homemodder  Portugal
Hi Kchu
Good that you now know which transistors are blown, replace only those ones together with their complementary, that is if the transistors you purchased are complementary.
Big gains can be had from rotels in upgrading the preamp. Those ICS are what destroys the sound of these amps competing against some of the best here. I personaly have bypassed the preamp on my old 972 and and with a change of compensation this amp can kick a lot of *** compared to some very expensive gear and diy designs here, and at very low cost. But having a preamp is sometimes a practical thing, depends on how you wanna use the amp.
Let me get schematic then ill tell you a little more. But yes a change to better opamps will improve sound but youll have to spend quite a bit more to get better ICs. Those Ics are good mid to low hifi chips, ive heard good things about lm4562 maybe they are better and can be drop in replacements. Ive used ad826, ad 827 ad828 with very good results but these cost about 3 times more than the regular opamp.
What no blackgates, in your Amp?????, mine which is a 12 year old model only have blackgates, Maybe they only used them in certain critical positions like for decoupling inputs.
Im talking out of my head, let me download the schematics and have a look.
Alex
Old 1st June 2008, 04:40 PM   #30
Hi Alex,
What can be done to the pre-amp to improve sound quality instead of bypassing it.
Thanks,
Kevin
HELP! Rotel RA-1062Hide this!Advertise here!
Rotel RCD 855 tonitze Digital Source 20 20th December 2016 11:04 AM
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 9 1st March 2016 11:40 AM
Rotel RA 931 argonrepublic Chip Amps 0 20th April 2009 02:26 AM
Rotel RC-850 Pre Amp + Rotel RB-870BX bleachershane Analog Line Level 4 9th February 2009 12:20 PM
Phonic powerpod 1062 dead channel disassembled Solid State 0 7th July 2008 05:44 PM
Copyright ©1999-2017 diyAudio
