Hi there everyone,
Well, I'm back and with more questions on amp building. Currently I want to find a simple DIY amp project that can produce 100W+ @ 4ohms in a monoblock with class ab operation. I was wondering if anyone knew of some PCB that already fulfilled this requirement that would be a good place to start. Cost is a factor, so obviously a compromise is needed. Nothing more than $120 an amp would be nice to say the least (cheap being better, without sacrificing too much). I'd also like to avoid a chip amp for the sake of actually learning something this go. Any ideas and suggestions? |
#2 |
You could try the SymAsym, should be right up your alley.
Doctor Bittner will see you now
Looks like Sponge Bob has killed another thread. |
#3 |
I just finish building an amp based on the LME49810 chipset with 2SA5200/2SC1943 o/p transistors with 45Vdc you get about 100W/channel. I use 34Vdc and still it sounds very good much better than comparable power from gainclonne LM3886. I have both and make direct comparison.
I paid for a kit set with all components except transformer and power supply components. Costs US$26/channel, cheap, sound very good, good clarity, dynamics and easy to build. If you are interested, search for LME49810 and monkey, the company is based in China and service is good. I can recommend the kit. The website is listed under monkey's profile. I am not associated with the company just a user. |
| 807 monoblocks | sarrisk | Tubes / Valves | 13 | 28th August 2008 08:04 PM |
| UCD-180 Monoblocks? | audioferret | Class D | 44 | 12th March 2006 09:48 PM |
| my first GC monoblocks | SM7UYJ | Chip Amps | 12 | 6th January 2005 07:41 AM |
| Big Monoblocks | SmarmyDog | Solid State | 11 | 25th October 2004 07:01 PM |
| A75 Monoblocks | Peter Daniel | Swap Meet | 30 | 9th May 2002 11:46 PM |
| Page generated in 0.06687 seconds (70.48% PHP - 29.52% MySQL) with 10 queries |
