Class A biasing for the AD797?
Old 26th May 2008, 06:00 PM   #11
jcx is offline jcx  United States
my sims with a ~500uA biased complementary follower added to my loop gain sim of the AD797 simplified schematic shows no difference in the IMD products with optimum Cn vs 15 mA ccs output bias for 20+21 KHz 1:1 with 10 mA peak output into the resistive load (feedback network) @11Vpk out 1KHz IMD is -120 dB with either approach
I don't believe that the output stage is the dominant distortion source in this example, I have found a "T" 2-pole compensation that in sim reduces the 1 KHz IMD to -126 dB, the compensation "coincidentally" shows peaking in the loop gain at 20 KHz – reducing the amplitude of the main signal components at all stages, both diff in v, and folded cascode i
rather than improving active device distortion performance it is possible that full Class A operation improves “parasitic” system level distortion mechanisms
when a Class AB stage drives a load with higher current than the Class A bias, then part of the time one output stage transistor is supplying all of the current from one supply V and the other is cut off, with the roles reversing for opposite signal polarity, this means the current in the power supply pins looks "half-wave rectified" - ie highly nonlinear
these nonlinear supply currents can cause nonlinear distortion in the amplifier/system even with perfect active device amplification - the nonlinear supply currents can couple inductively or through the return currents flowing in impedance in common with the signal
If the amp operates full Class A then the power supply currents are linear and parasitic coupling only slightly changes gain/frequency response and crosstalk without adding nonlinear distortion
I prefer a physically separate buffer/gain stage in the feedback loop to avoid loading and thermal feedback effects in the precision input op amp, the buffer stage could also be Class A to avoid the above"system parasitics" distortion mechanisms
In the case that the load is known and constant it is also possible to add a negative impedance amplifier in parallel with the precision op amp's output stage – I think this circuit was shown by Sandman – when the negative impedance matches the load impedance then most of the output current is supplied by the added negative impedance circuit's amplifier and the AD797 output wouldn't operate beyond it's +/- 1 mA Class A region – Sandman's circuit has the “advantage” of not adding “stages in series with the signal path” for those bent that way
Old 26th May 2008, 06:25 PM   #12
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Thanks a lot, jcx,
for your comprehensive answer. Is this the negative impedance approach you're talking about?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 26th May 2008, 06:32 PM   #13
KSTR is offline KSTR  Germany
KSTR's Avatar
Hhm, I think it's this one:
The Design and Build of a Class ‘S’ Audio Amplifier
- Klaus
Old 26th May 2008, 08:12 PM   #14
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
About biasing monolithic opamps to class A. It's very easy to try with a resistor, CRD or JFET (maybe not as good as bipolar). I've done it a lot (not with AD797) and thought the world of it... until I tried it live - connecting/disconnecting it while playing. No bloody difference at all! It was all placebo.
BTW, what is the optimal implementation of AD797, resistor/capacitor values?
Old 26th May 2008, 08:21 PM   #15
Onvinyl's Avatar
404, Klaus
Old 26th May 2008, 08:33 PM   #16
KSTR's Avatar
Sorry, Mr.Higgins' main page says "Back Soon"
Reference:
The Design and Build of a Class ‘S’ Audio Amplifier. Matthew Higgins.
ES327: Third Year Project Final Report.
School of Engineering, University of Warwick, UK
If you PM me your email I could send you that paper (2.3MB)
- Klaus
Old 26th May 2008, 10:00 PM   #17
Onvinyl's Avatar
Klaus, My email-button should work now
Old 26th May 2008, 10:04 PM   #18
KSTR's Avatar
Ahm Rüdiger, better PM/email me (so that I have your email address), because there is no attachment option here.
Old 26th May 2008, 10:44 PM   #19
U2 is the precision amp, U1 is the cheap op amp negative impedance “buffer”
the combined load on U2 output is (R4+R5)||R6, where R4,5 are the feedback network and R6 is a load
R3 is a 10x scaled copy of the U2 load, the V across R2 might be thought of as measuring the current required to move R3 with the same V as the U2 load, R1 converts the measured voltage to a scaled current that just cancels the U2 load's current requirement – to the degree that R3 is an accurately scaled copy of the total load Z
U1 can be seen supplying nearly all of the load current in this sim through R1 (yellow)
U2 output current is ~260 uArms in this sim (red), mostly because at 20 Khz there is some phase lag in the synthesized negative impedance due to U1 GBW, a ~98% cancelation which should be better at lower frequencies - within the limits of component tolerances
Old 27th May 2008, 12:01 AM   #20
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally posted by nelsonvandal
Is it possible to tap the signal from the decompensation pin 8 (point B in the simplified schematic) and connect it to a discrete output stage and wrap it in the feedback loop instead of the built in diamond buffer, just like you can from the compensation pin in AD829 and AD744?
This might be OK, but I'm not sure of the possible pitfalls.
There seems to be a lot of interest in this stuff I'm sorry I don't have more time to reopen the files.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Class A biasing for the AD797?Hide this!Advertise here!
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 06:40 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 04:45 AM
Class A/B Biasing bowdown Solid State 3 23rd September 2004 01:56 AM
