Old 14th May 2008, 03:23 PM   #1
Default I need the Sima W-3050 or W-2002 schematic
Hello
Anybody would have the schematic of the Sima W-3050 or
W-2002 power amp ?
Thank a lot
Bye
Gaetan
Old 16th May 2008, 02:55 PM   #2
Hello
The Sima W-2050 and W-2003 power amp are quite same than the others one, anybody would the schematic for them ?
Thank
Gaetan
Old 16th May 2008, 04:18 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
seems such schematic is not in internet
i did some google - but nothing found
i am sure some other member would have a schematic
so, if you are lucky here you may have one emailed within 1 week
otherwise, i would say you can try to get in contact with the designer
Victor Sima .. or the people around him
Victor Sima
Proud creator of the entire Linar line as well as
founder and ex-owner of SimAudio
( from this page: http://www.linaraudio.com/NYshow.htm )
The email to Linar Audio is:
linar (at) vif.com
regards
lineup
Old 16th May 2008, 04:36 PM   #4
diyAudio Moderator Emeritus
If it resembles Linar, maybe this can help you. It's non-global feedback amp, servo, DC coupled. Output transistors and input fets are erased, they could be C5200 and K170?
Old 16th May 2008, 04:50 PM   #5
Hello
Sima amp are 20 years old amp design was before Victor Sima sell his company to Sim Audio, so Linar amp are very different design from Victor, btw a friend of mine do have a Linar 10 and that amp sound superb.
Thank
Gaetan
Old 23rd August 2008, 04:08 AM   #6
Unhappy Hi, my 3050 lost one Ch...
so I to find out I took the board the drew the schematic. I have it on paper somewhere. It uses double diff. pair on input (mpsa 8099, 8599), MPSU07, 57 as predrivers and the MJE15030/21 as drivers and MJ15023/24 out trans. I have problem getting the MPSU07/57 as the smoked , maybe there are newer transistors that could be used as the predriver pair . I thing Victor will not be pissed if send the schematic ( I have to drew it on the Spice) , since all his new amps are no feedback design.
mail me back
Old 24th August 2008, 03:20 AM   #7
Default Re: Hi, my 3050 lost one Ch...
mail me back
Hello
I would be very please if you can send it to me by email.
I have sent you a private message.
Thank a lot
Gaetan
Old 24th August 2008, 03:52 AM   #8
MPSU07, 57 as predrivers and the MJE15030/21 as drivers and MJ15023/24 out trans. I have problem getting the MPSU07/57 as the smoked , maybe there are newer transistors that could be used as the predriver pair ...
Hello
MPSU07, 57 as predrivers, I presume it is the transistor for the VAS, those MPSU are slow at 50 mhz, but using much faster modern transistors like 2SC4793, 2SA1837, KSC3503, etc.. may need to change the value of the cdom capacitor, but the BD139 and BD140 would do the job since they are just a bit faster than the MPSU transistors.
Gaetan
Old 25th August 2008, 04:38 AM   #9
Default Hej
"like 2SC4793, 2SA1837, KSC3503" I though about the 2SA1837/2SC4793 pair. The BD139/140 is older design might not even be faster than the MPSU's 50-100MHz, what is interesting about the MPSU07/57 is that the Cbo is only 6-12pF (Vcb=10V, Ie=0 f=100khz). Have no idea why Victor used then. Then there is Unisonic (UTC) 2SD669 with low Cbo as well. Also Toshiba 2SA1930/2SC5171 seems OK.
Sorry but I worked on W-kend and didn't do SPICE work for you. My 3050 has 4 transformers instead of two as in original units - maybe two drive low impedance spkr. It's an OK amp, transparent, not soft or romantic, nothing like the later non feedback Celeste 4070(se), 4150 or the latest from Linear, which use MJL21192/93 in the output, I assume. One think I learned from the ordeal: don't bias the output trans more than 10mA per MJ15022/23. Originally they are biased around 5mA (but it did lower the harmonic distortions as my Clio showed)
Paul
Old 3rd April 2010, 09:12 PM   #10
Hello
I've open the Linar amp of a friend, we can't see the number on the output transistors, but after asking mr. Sima, it is mosfet output transistors, but I did not give me to number of those mosfet.
Bye
Gaetan
I want to build this amp need schematic LP 2002 Jonny Hotnuts Car Audio 10 7th June 2008 01:15 AM
Looking for schematic/info for a Knight KN 3050 PA Amp camusmuse Tubes / Valves 3 12th May 2008 10:21 PM
sherwood 3050 CD vubkevin Digital Source 1 31st August 2007 09:50 AM
Page generated in 0.10986 seconds (82.75% PHP - 17.25% MySQL) with 11 queries
