Hi everyone,
Im looking for a useable Op-Amp or possibly a simple discrete circuit to use as an input buffer on an amplifier I'm planning. The buffer stage should be unity gain and preferrably low noise and low distortion. I've currently been looking at the AD797 and OPA134. Judging by the datasheets (and price...) I understand that the AD797 performs better with respect to distortion and noise. However, as the AD797 is quite costly (this is a somewhat unusual application where I'll need as much as 12 Opamps) compared to the 134, I'm wondering if it's worth the extra expense? Using AD797s will cost US$110, while the same number of 134s will get me there for around $30. Also - I've been looking for a simple buffer stage as an alternative - does anyone know a suitable circuit that does the same job as the opamps in this context? |
#2 |
Discrete OpAmp, amplification -1.
#3 |
Thanks for replying, but wouldn't it be a bad idea to put an inverting buffer stage in front of a non-inverting amplifier?
Also, any idea on distortion, PSRR and other performance parameters compared to an IC OpAmp? Since it has only passive loads/current sources on the input stage, wouldn't power supply noise get quite easily injected into the signal path? |
#4 |
Specs are not known to me,.
This is no opamp design for optimizing any spec. With the named transistors you could build a MM-amplifier. Because of the low amplification distortions are low. I would take a stabilized power supply anyway It is a design to built with little effort and cost. It can be modified for +1. |
#5 |
The Hafler circuit looks like something we would have put together 40 years ago. It is not bad, but flawed.
#6 |
Electrons are yellow and more is better!
Have you checked the LME49710, pretty cheap and pretty good. AD8610 is very nice also, in fact you have lot's of good opamps to choose from. OPA227 good.
/Per-Anders (my first name) or P-A as my friends call me |
#7 | |
The first question: An inverting amp is a bit sensitive for the signal source and it's output impedance (including a pot) and the input impedance can't be made particulary high. The obvious advantage isn't so obvoius.
#8 |
Very few op amps really work well at unity gain. I usually design them out. Fet followers are better, sonically.
#9 |
That might be so but I think you must also consider how advanced the PS must be and also the skill of the builder. A simple JFET source follower is rather easy to get going, hard to fail.
#10 |
Do you find any difference sonically in inverting or noninverting OpAmp configuration, and particularly at low gains ?
| Discrete AD797 up and running | nelsonvandal | Solid State | 105 | 23rd February 2010 06:54 PM |
| AD797 discrete clone - comparison of seven variations | tiefbassuebertr | Solid State | 14 | 9th January 2010 11:52 AM |
| Best place for discrete buffer | Khron | Chip Amps | 8 | 11th March 2006 05:16 PM |
| Discrete buffer stage for xover | JoeC | Everything Else | 1 | 2nd February 2002 03:43 PM |
| Page generated in 0.11135 seconds (78.98% PHP - 21.02% MySQL) with 11 queries |
