Aerogel capacitors - diyAudio
Old 11th March 2003, 04:23 PM   #1
Default Aerogel capacitors
Has anyone heard anything on this Powerstor Aerogel Supercapacitor sold by Mouser?
http://www.mouser.com//index.cfm?han...et&pdffile=284
Today I was searching Mouser's Web catalog and found these. They are expensive, made with carbon foam and have low ESR.
Perhaps an alternative to BGs?...
Carlos
Old 11th March 2003, 04:46 PM   #2
tiroth is offline tiroth  United States
Nice find. Those are some huge caps! However, I'm not sure these will be better than other supercaps.
Although PowerStor aerogel supercapacitors have very
low resistance in comparison to other supercapacitors,
they do have higher resistance than aluminum
electrolytic capacitors and are more susceptible to
internal heat generation when exposed to ripple
current. Heat generation leads to electrolyte
decomposition, gas generation, increased ESR and
reduced lifetime. In order to ensure long lifetime,
the maximum ripple current recommended should not
increase the surface temperature of the supercapacitor
by more than 3C.
Product info:
http://www.cooperet.com/products_supercapacitors.asp
Old 11th March 2003, 05:40 PM   #3
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Is it me or it's just a typo ?
The capacitance for the AeroGel capacitors is stated in Farads (F) and not in microFarads (uF)
I'm quite surprised to find 50 farads capacitor under 20$ each
Just wondering
Old 11th March 2003, 05:49 PM   #4
FunkyStu's Avatar
Just for info the values are correct but notice the very low operating voltages.
The aerogel stuff is pretty funky though ! Check out this page.
http://stardust.jpl.nasa.gov/tech/aerogel.html
Old 11th March 2003, 05:50 PM   #5
SY's Avatar
It's you. That's no typo.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th March 2003, 05:52 PM   #6
Steve Eddy's Avatar
Nope, it's not a typo. Though they're not your typical aluminum electrolytic type capacitors. The technology used allows for a huge amount of surface area within a very small package compared to normal electrolytics. Various kinds of "super caps" have been around for years. Just that they typically weren't suitable for applications other than memory backup due to their high internal resistance.
These aerogel caps have a much lower resistance than the older "super caps" but they're still only rated at 2.5 volts so you'd have to string them together in series to be able to handle higher voltages which reduces capacitance and the internal resistances add.
Ultimately you'd need to series a bunch together, and then parallel a bunch of those together in order to get suitable voltage handling and internal resistance. Then the cost isn't so cheap.
se
Old 11th March 2003, 05:54 PM   #7
Default not a typo
Farads. Strange concept to grasp since back in the olden days, we used wierd examples of what a farad actually was - copper plates one mile apart and such.
Now every kid with a stereo in his car is getting one of these "stiffening" caps put in. That his cheap amp cannot really benefit from it is another story.
Old 11th March 2003, 06:00 PM   #8
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
seems they also have 2500f caps as well
Old 11th March 2003, 06:36 PM   #9
Steve Eddy's Avatar
Yup. But of course only 2.5 volts.
These kinds of caps aren't particularly new technology. <a href="http://www.maxwell.com">Maxwell</a> has been making them for some years now (they call 'em BoostCaps now, but they used to be called PowerCache).
Though it's nice to see the same type of capacitors readily available through stocking distributors like Mouser.
Here's a Maxwell module (made using multiple seriesed/paralleled caps) that will give you 145 FARAD of capacitance at 42 volts.
<a href="http://www.maxwell.com/ultracapacitors/products/BMOD0115.html">http://www.maxwell.com/ultracapacito.../BMOD0115.html</a>
se
Old 19th December 2004, 06:37 AM   #10
Send a message via AIM to joe carrow
I was just bowsing Digi-Key for parts today, and saw a 50 farad capacitor for $26. That makes me want to ask two questions-
First, isn't it possible to wire capacitors in series/parallel to get a large capacitance with a higher tolerable voltage?
Second, has anybody used these, or seen them used, on a cool project?
Joe
Aerogel cones? Javachip Multi-Way 33 2nd October 2012 02:57 AM
Audax Aerogel cone technology? JoshuaTechnomage Multi-Way 7 12th June 2009 08:17 AM
Kevlar, Aerogel, Carbon Fibre, Paper - Which is the best ? Fanuc Multi-Way 12 4th February 2009 08:06 AM
Aerogel as a loudspeaker stuffing material Oborous Multi-Way 13 21st November 2006 07:58 PM
Audax AP210Z0 8" Aerogel Midwoofers BAM Multi-Way 5 17th November 2006 10:03 AM
Copyright 1999-2017 diyAudio
