Old 7th May 2008, 07:15 PM   #1
Default Technics SU-G90 no display or sound
Hi!,
This unit had intermittent output and I tried to help a friend by expecting to find dry joints. I found a few, but the fan was not working so while I was tracing the circuit my hand slip and I now have no display or audio. I have voltage on pin 4 60volts and lights on the function buttons. Q705 transistor seems to run hot as the circuit board is discoloured. I have no schematic and would appreciate any help I will give more info if needed. Looking forward to someone pointing me in the right direction.
Thank you
Tony
Old 30th October 2010, 04:56 PM   #2
My sons each purchased a Technics system which included these power amps. Both amps have the same problem with intermittent audio and display. Anyone have any ideas of whats causing the problem?
Old 30th October 2010, 06:11 PM   #3
sakis is offline sakis  Greece
sakis's Avatar
i only have available su-g 91 schematic and you are welcome to have it .... just e mail me ... Please notice that most of these models have a circuit with ventilator with a sensor ...meaning that if the speed of the fan is low for any reason of failure or simply cause the fun is broken the amp goes on protection mode
in your case obviously there is going to be more than that.... I epect schematics to be the same only 91 might be more powerfull
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 30th October 2010, 06:24 PM   #4
The fan circuits in both amplifiers work. It appears the problem exists within the connections between the front panel and the main mother circuit board. It must have been a common problem because both these power amplifiers exhibit the same condition. If you tap on the box the interment goes and comes back! I am wondering if anyone else has found the source of the problem?
Technics SU-A8 preamplifier, no sound, help please! cchean Solid State 2 7th April 2009 06:30 PM
only right sound from my Technics SL-1200 kollisionseb Analogue Source 3 12th February 2009 10:59 AM
Technics SA500-No Sound john Savarese Solid State 1 6th September 2007 05:47 AM
Technics SA-310 won't make sound tonyroma Chip Amps 8 23rd May 2006 01:11 PM
Page generated in 0.08497 seconds (71.58% PHP - 28.42% MySQL) with 10 queries
