#31 | |
Hi, HF gain is set by the input stage gm and Cdom of the VAS. For a typical output stage and Cdom stabilisation you can get away with up to ~ 30dB excess gain, or feedback factor at ~ 20Khz. The exact numbers are always imprecise, the question being usually how much phase margin is enough ? never an exact answer .... /sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#32 |
Thank you for all the replies. I have designed a spreadsheet that calculates my values/components required for a input & vas stage that will be stable based on the recommendations throughout this threat and another one which should produce a very linear design but I am concerned with the stability. Attached you will find the circuit, graph 1 (OLG=Red, CLG=Blue and Output=Green); (Phase=Green), graph 2 (3rd Distortion measured in volts); graph 3 (3rd Harmonic measured in dB) and a printout of the spreadsheet. Can someone please look at the ouput of the input&vas and advise whether I can pursue this design based on my current configuration. Thank you, CorrieB |
#33 |
examples loopgain.asc and loopgain2.asc in ltspice are used to plot the open loop gain.
example audioamp.asc is refered as to look the gain and phase margins. which one is better to be used? if we have a 30db gain amplifier ,can we plot the open loop gain based on the formula on loopgain example,then go at 30db at the open loop gain graph and look at the phase margin corresponding there?? |
| opamps used for unity gain | HiFiNutNut | Solid State | 25 | 12th April 2011 02:34 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Unity Gain (AV=1) Zen Amp | LS | Pass Labs | 2 | 16th September 2004 04:40 AM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
| Page generated in 0.08461 seconds (70.35% PHP - 29.65% MySQL) with 11 queries |
