Need help for JFET amplifier
Old 6th May 2008, 08:38 AM   #1
goodnight521 is offline goodnight521  Andorra
Default Need help for JFET amplifier
Can anybody recommend a discrete JFET preamplifer whose voltage gain is over 10 with supply voltage is 5V.The frequency of input signal is from 0.1Hz to 20Hz.
I have tried numerous JFET tubes to build up circuit working at Q point but can't get enough gain at low frequency.Attachment is schematic with pspice.
Thanks!
Old 6th May 2008, 01:07 PM   #2
Mooly's Avatar
0.1 Hz to 20Hz, Why not use a FET OpAmp designed for low voltage single rail use. Much easier, much better performance.
What are you trying to do ?
Or a bipolar OpAmp with discrete FET front end.
Need help for JFET amplifierHide this!Advertise here!
Can I use the 2N5484 jfet diff pair in an audio amplifier front end? carpenter Pass Labs 27 28th March 2009 01:55 AM
Pass JFET Power Amplifier Nelson Pass Pass Labs 447 17th March 2006 05:29 AM
Power JFET Amplifier? Steve Eddy Pass Labs 0 14th September 2005 01:28 AM
JFET voltage amplifier Banfi T. Solid State 17 15th January 2003 03:38 PM
