Old 6th May 2008, 02:12 AM   #1
Default Compressor / Limiter
I know that this forums is a little biased against any form of altering the original sound...
But I need to make a couple active baffles and would like to incorporate some form of limiter. I've seen somewhere a LED-photorresistor arrangement that begins acting just near clipping.
The LED and the LDR are in a light-tight enclosure. As soon as the LED begins to lit, the LDR lowers it resistance and hence the volume.
What is your opinion on this system? I think that always limiting is better than distortion...!
Old 9th May 2008, 12:54 AM   #2
no opinions?
Old 9th May 2008, 03:21 AM   #3
gni is offline gni  United States
gni's Avatar
Limiters are a good way to protect a driver.
I'm not sure the circuit described is the best circuit; if heard
that sometimes calibrating the optical portion of the circuit
is difficult. . .
Old 9th May 2008, 06:17 AM   #4
MaxS is offline MaxS  France
Hello
Dr Leach have publied a limiter on his website.
http://users.ece.gatech.edu/~mleach/
Max.
Ca marche pas ! Tu ne l' as pas branché non plus ....
Old 9th May 2008, 12:07 PM   #5
Originally posted by MaxS
Hello
Max.
Sorry, I'm having error 404
Old 11th May 2008, 05:28 PM   #6
Pbassred's Avatar
Send a message via MSN to Pbassred
The LDR method has been the of mainstay of many compressors going back to the early 1960s (maybe before?) . TFPRO designed their product range around it. TED Fletcher has written some interesting articles about it.
The good side is that they SOUND quite natural.
The bad side is that they don't react quickly so they might not be great at taking out spikes. (That said I used an old TF designed Joe meek unit in my bass rig and it held back my unplug thumps well.). Also they are not linear, but then TF would say that they are aligned with natural hearing perfomance and make it sound louder ( google that!).
Jeeees! I only asked
www.davethebass.com
Old 12th May 2008, 03:50 AM   #7
The earlier versions of this compressor used a lamp bulb, with it inherent low speed they would react quite slowly to peaks.
The version with an LED has a fast attack and low decay, much like the human hearing.
I am not much concerned about clipping a fast peak or two, as long as the sound is more or less undistorted. I find its sound acceptable.
Urei 1176 Ln Audio Compressor Limiter Manual Circa 1973 mv331 Swap Meet 0 21st May 2009 05:37 AM
Opto FET compressor/limiter fjpompeo Everything Else 3 17th January 2008 06:15 PM
Mic compressor limiter fjpompeo Analog Line Level 0 1st June 2007 10:26 PM
any suggestion for limiter and compressor for a bass guitar ? Ahmad_tbp Instruments and Amps 4 27th January 2006 09:53 PM
Compressor & limiter effect help plz ... Ahmad_tbp Instruments and Amps 4 5th March 2005 05:30 PM
Page generated in 0.10060 seconds (74.99% PHP - 25.01% MySQL) with 11 queries
