Having searched the forum I found references to lapping heatsinks but no mention of how effective it is or how flat a surface should be.
I'm servicing an old 500W/chan MOSFET amp. I know that heat was a concern with that model. The fets are bolted to an "L" section which is bolted to "U" section, which in turn. has 2 progressivly smaller "U" sections nested inside it. The previous application of thermal grease was unevenly "lumpped" in. Am I insane to even bother? edit:- P.S. I'm talking about the junctions between the lumps of metal, rather than the TO3s themselves. |
#2 |
Can you omit any of the intervening couplings?
The closer your FETs to the heatsink the better. A flat and polished surface is desired. But most will settle for a flattish surface finished with 600grit. All air spaces at the interfaces must be filled with thermal compound and the maximum areas in direct contact the better.
regards Andrew T. |
#3 |
Thanks for the 600 grit number.
Unfortunatly, I can't build it any differently to its design. I might be able to do something about air flow through the sections. The early model had a more basic heatsink. When I got one the lid had been thrown away to ventilate it. The Mk2 had a more elegant heatsink and more air holes - all signs that there may have been a cooling concern. That said, I'm sure my Mk2 led a full and happy life before I got it. I'm just trying to enhance. When I get it back together I'll do some Left/right comparrasons. If the rebuilt right side heatsink gets warmer than the left, it must be removing more heat. |
#4 |
Just out of curiosity, can you post a photo of this arrangement?
..Todd |
#5 |
Surface finish must be 0.002" to use white thermal compound, 0.001" to use clear.
Surfaces mated with clear must be re-surfaced when dis-assembled and re-assembled, or use the white.
Candidates for the Darwin Award should not read this author. |
#6 |
I'll try and get a photo tonight.
Meanwhile, someone told me that thermal transfer pads have improved a lot in the last 20 years so I might get more practical results replacing them. I'll still lap between plates though. |
#7 |
If it helps, I use 600 grit taped to a sheet of glass, resting on the bed of my table saw.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 | |
the thermal pads have a variation from best to worst of about 10:1 in conductivity. In the middle comes a typical 0.002inch mica washer with thermal compound to both faces. A direct metal to metal interface with thermal compound (to exclude the air) will far outperform any thermal pad or other type of conductor.
regards Andrew T. |
#9 |
I have a bit of experience with lapping heatsinks (and CPUs) for overclocking in PC's.
sheet of water paper glued to a mirror... Overall the increase in thermal performance is small enough to be almost negligible... maybe gain 3C of heat headroom... I would rather look at getting the sinks anodised black (if they are not allready) this will produce a much higher margin in my opinion.... |
#10 |
Another idea is to use Kapton (polyimid) Isolation Tape, which will also provide excellent heat transfer due to it's minimal thickness. I've bought those 2 rolls for less than $20 including shipping. Just search the well known internet shopping platform for Polyimid... (from China)
cheers
regards / servus |
| FS Heatsinks | woody | Swap Meet | 0 | 25th March 2008 10:41 PM |
| about heatsinks | bigpanda | Solid State | 2 | 4th May 2005 03:34 PM |
| Heatsinks | DD_Davo | Chip Amps | 2 | 13th April 2005 01:00 PM |
| SK-109 Heatsinks | Leeuwarden | Swap Meet | 8 | 11th December 2004 09:19 AM |
| Heatsinks for DoZ | ultrachrome | Solid State | 0 | 4th February 2003 09:23 PM |
| Page generated in 0.11579 seconds (84.45% PHP - 15.55% MySQL) with 11 queries |
