best voltage follower, discrete opamp and whatnot
Old 4th May 2008, 05:10 PM   #21
Mooly's Avatar
Originally posted by gearheadgene
You know, Doug Self claims the 5534 is about as good as they come I guess he tried to build better circuits, unsuccessfully. Never mind what you may think of Doug Self, the 5534 sure looks good in simulation. If it has a fatiguing sound to it, then it sure would be nice to figure out why. Changing monolithic opamps on a circuit board is easy enough. But, the discrete stuff is going to build and trash, if it doesn't work out
I have a lot of time for Doug's work, his insight and theoretical knowledge in this field is second to non, but, and it's a big but, his designs while achieving remarkable technical proficiency fail to varying degrees at the final hurdle-how it sounds. The answer Doug will give is, "show me the evidence in some measurable form". I certainly can't. But my ears tell me ! The 5534 is not a bad OpAmp, far from it, but in a top flight system it is easy to demonstrate the "subtle" change swapping to a different type can produce. It's a matter of degree's, in absolute terms the difference is tiny, from a musical perspective it's enormous.
Only you can decide what works for you. If you can get hold of a squarewave generator do build a test circuit and 'scope the output. Try a 5534 and a TLO71 for starters.
Regards Karl
Old 4th May 2008, 05:14 PM   #22
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
Originally posted by MikeB
When simulating a "high input impedance voltage follower", never forget to add a big resistor (~100k)...
Sorry, I'm a bit of a noob, but why 100k? I thought most modern CDPs or DAPs have a very low output impedance.
Originally posted by jam
Nelsonvandal,
.................sorry to burst your bubble but it has. I have used variations of it with good results.
Jam
It really wasn't meant to be a bubble, just a stupid question . Thank you for sharing your schematic. I'm going to try to use these JFETs in my little headphone "le classe A". The input stage is a typical diamond buffer.
Old 4th May 2008, 05:23 PM   #23
R.I.P.
I think what he is saying is that adopting a zero to low source impedance forces the simulator to report unrealistically low distortion predictions.
regards Andrew T.
Old 4th May 2008, 05:26 PM   #24
MikeB is offline MikeB  Germany
MikeB's Avatar
In this case the buffer would be unnecessary.
Well, try at least 10k, which is realistic if you have a 10k volume pot after the signal source.
The reason why this is important, is, the largest amount of distortion with buffer circuits is not produced in the buffer itself, it is created at the input. An unlinear behaving input attached to a not low impedance source creates vast amounts of distortions.
Diamond buffers do a very good job here.
As Andrew said, the distortions predicted with a 0ohm signal source are unrealistic low.
Old 4th May 2008, 06:52 PM   #25
jam is offline jam  United States
jam's Avatar
Nelsonvandal,
JSorry! ust giving you a hard time.......
This is what you need................you could probably get away with leaving out the servo.
Jam
Old 4th May 2008, 07:31 PM   #26
MikeB's Avatar
Whoooaa! What a monster!
May i suggest something more simple and functional...
It has very high psrr, thd = 0.0002% (20khz,1v,1k) practically independent of source impedance, low dc-offset, simple, output impedance near zero.
It might need refinement in detail.
Old 4th May 2008, 08:12 PM   #27
MikeB's Avatar
Or, may i introduce "Cadibu"?
Similar performance, but less good dc-offset... But, cheaper.
Mike
Old 4th May 2008, 09:12 PM   #28
KSTR is offline KSTR  Germany
KSTR's Avatar
Michael,
Your feedback JFET buffer is a clever design!
When extremly controlled DC-offset is not a big issue, I suppose it would work well with selected and thermally coupled BF245C's, BF861C's or similar and then being a low cost design as well.
- Klaus
Old 4th May 2008, 09:20 PM   #29
MikeB's Avatar
It's not really a feedback design. It's a constant voltage, constant current design, sadly not mine. The principle is from steven.
The idea is, a device having no voltage/current fluctuations does not distort by principle.
Mike
Old 4th May 2008, 10:06 PM   #30
KSTR's Avatar
As usual, it's a matter of viewpoint wether we call it feedback or not
Actually I made my way through the circuit regarding the PNP as the error amplifier which tries to establish a constant Vds accross the FET by controlling the NPN current sink. This controlled current sink also gives the low Zout of 0.1R, rising from ~20kHz with a 6dB/oct slope to ~10R at 10Mhz, as per sim (also getting your ballpark THD numbers). All this confirmes the feedback view, giving the gain values of a single simple common emitter stage. It is not direct signal feedback, of course, rather it is somewhat indirect via the constant Vds and constant Id.
Do you have a reference/link to the circuit (I don't know which Steven is meant)?
- Klaus
best voltage follower, discrete opamp and whatnotHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
My discrete opamp udip Solid State 51 8th August 2006 07:33 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
