Hello,
does anyone know the settings for the bias and dc of the Musical Fidelity B1? Which setting I will have to adjust first, and will be a voltmeter sufficient? (A scope is also available) The FETīs are 2N3055. All the best, Salar |
#2 |
has your B1 been repaired?
regards Andrew T. |
#3 |
By myself,
swapped the power transistors and electrplytics last year. I own it now for 18 years. Until then, the B1 was faulty, had a distorted noise on the right channel after being powered up during the first minutes. This was repaired about 10 years ago but the problem reoccured. I always let the amp switched on but after the amp finally blew last year I decided to do it myself. It now runs without problems but i want to be sure, that the levels for bias and dc are correct. I also have sometimes the feeling of hearing a slight distortion, crackling, i.e when listening to trumpets or dynamic material. But I could not hear any distortion when playing testtones like pulses or sawtooths. All the best, Salar |
| MUSICAL FIDELITY A2 Quiescent current / Bias problem Right Channel | sviru | Solid State | 22 | 6th August 2009 05:58 PM |
| Help Musical Fidelity B1 | moatic | Solid State | 2 | 6th December 2006 02:52 PM |
| 2sj48 bias settings | Frans R | Chip Amps | 0 | 5th November 2006 09:16 AM |
| Musical Fidelity B1 | NamWong | Solid State | 1 | 29th April 2004 01:46 PM |
| Musical Fidelity PR-70 | dinamic1 | Solid State | 0 | 29th April 2002 08:41 AM |
| Page generated in 0.06434 seconds (69.28% PHP - 30.72% MySQL) with 10 queries |
