Cyrus 2 no output after short fall
Old 3rd May 2008, 08:47 AM   #1
WNR is offline WNR  Australia
Question Cyrus 2 no output after short fall
My beloved cyrus 2 built 1986 recently fell about a foot front-first off a low shelf and, perhaps not surprisingly, wasn't happy about it ? Power on is OK but there is no output using the CD input. All I can hear is a very weak ouptut through the L channel only, barely audible and it doesn't increase when the volume control is increased. I have removed the cover and cannot see any obvious physical damage.
I am a Pom currently living in Sydney and a chemist by training. Though not great with electronics I can find my way around a schematic and have access to 'scopes etc. and electronics labs and friendly electrical engineers if necessary. I would appreciate any advice on troubleshooting this problem. I have the issue 07 cyrus 1 schematic from this forum. Alternatively any suggestions for repair shops preferrably in Oz or in the UK (will be back there briefly in Jan 09 if not before) would be great.
Many thanks in advance
Bill R, Sydney
Old 3rd May 2008, 09:12 AM   #2
the volume control probably hit the floor.
It may have cracked the pot track or the connection to the PCB.
Do any other inputs still work correctly?
regards Andrew T.
Old 3rd May 2008, 09:18 AM   #3
MadMutt is offline MadMutt  Australia
If it landed front first on the selector knob, and the cd input is the only fault, I would say the selector switch is broken.
Old 3rd May 2008, 01:25 PM   #4
Mooly's Avatar
PCB cracked around input sockets, was it connected at time.
Old 11th May 2008, 10:14 AM   #5
Hi Andrew, MadMutt & Mooly,
Thanks for your posts which prompted me to investigate further:
No, all inputs behave in the same way - hear L channel (only) at v low volume, with no response to volume control.
The volume contol has indeed taken a hit. The rearmost of the 2 small vertical mounting boards has broken completely in two allowing the control to be tilted forward at a crazy angle (see image apologies for quality).
Are their actually traces on that rear PCB or is it purely mechanical - it's hard to see?
I guess that at least that whole volume contol assembly will need to be checked out and repaired. Any practical tips for doing that - it doesn't look easy to get at? I haven't yet removed the main board from its metal case.
Selector switch seems OK.
All the inputs behave the same way. Yes it was connected at the time, but I guess I should investigate the vol control issues first?
Cheers, Bill
Old 11th May 2008, 10:18 AM   #6
Mooly's Avatar
Looks pancaked to me. You need a new one, at least if you can't repair the PCB. The board within the pot may well be cracked as well.
Regards Karl
Old 11th May 2008, 01:10 PM   #7
Sonusthree is offline Sonusthree  United Kingdom
Sonusthree's Avatar
I managed to get an alps 'blue' into the Cyrus 2. It was a bit tight, some pin bending was needed and I replaced the balance control with fixed resistors (optional).
Martin
Old 23rd December 2012, 03:26 PM   #8
wolkenlos is offline wolkenlos
Hi Martin!
Is there a chance to get the model number of the poti an a workaround with the restistors? Thanks.
wolkenlos
Old 23rd December 2012, 07:43 PM   #9
jaycee is offline jaycee  United Kingdom
The Cyrus 2 effectively has a passive pre. You can leave the balance pot disconnected without any resistors. A good quality logarithmic volume pot is all you really need. The original is a 10K pot.
Old 24th December 2012, 01:14 PM   #10
Well thank you.... Jaycee - I will try to get one of these alp blue 10K
This Model?
http://www.partsconnexion.com/product7384.html
My Problem with the Cyrus 2:
The left channel is more quieter than the right. Since the balance control does not work I thought that maybe this is the reason. Volume Power of the left channel 50%
regards
wolkenlos
Cyrus 2 no output after short fallHide this!Advertise here!
Where do we most often fall short with amps? walker Solid State 87 6th September 2010 06:49 PM
Short the Output of an Aleph X rsbay Pass Labs 9 24th November 2006 01:40 PM
output transistors for Mission Cyrus amp? hifihome Parts 3 12th March 2005 10:56 PM
speaker protection and output short patriz Chip Amps 3 10th January 2005 03:55 PM
Adcom GFA 555-II- Didn't like short on output :-( Magura Solid State 3 17th November 2004 02:17 AM
Copyright ©1999-2017 diyAudio
