Old 22nd January 2013, 01:41 PM   #191
Fairchild bds are using the same die as the bcs, onsemi have changed though.
Old 22nd January 2013, 02:03 PM   #192
RS232 is offline RS232  United Kingdom
By old I mean very old, I have brand new BD135/6 and BD139/40 with around 15 years.
I can always put in the MJE243/253 that X-PRO recommended.
I'm preparing an parts order for Farnell and a couple more transistors is not going to brake the my bank account (50xIRFP240 and a few other bits).
Ric
Old 27th January 2013, 05:51 PM   #193
New problem
Replaced the BC639/640 with BD139/140 (original Philips one from the 90s) but they still get very hot and after a few tracks on the cd player it just shuts of (no sound )
I'm I missing something ?
Some small heatsinks on the BDs ?
The bias is set to 15mv
Old 9th February 2013, 09:54 PM   #194
Ok, got this one working with the BD139/140 replacing the BC639/640 with a bias of 10mV.
On the the second one (DOA) I found a missing zener diode (ZD1) and a faulty ZVP3306...
After replacing the missing/faulty parts the amp worked fine (+/-2 hours), set up the bias to 10mV closed the amp power it up and nothing.
After looking for obvious faults I found out that the ZVP3306 was dead again...
Any ideas what can be causing the Fet to fail ?
Ric
Old 15th March 2013, 06:32 AM   #195
Hi everybody
Sorry for my english.
Very interesting thread.
I just look for serivice manual of A3i, my unit is faulty and i have only a partial schematic,
after some time it get very very hot.
I found my A3i in the trash, some jerk threw it away.
Gianni
Old 15th March 2013, 05:03 PM   #196
In case you didn't see the OP schematic and comments or search the web yet:
cambridge audio a3i Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
regards
Old 9th June 2013, 06:46 PM   #197
Hello all,
Thanks a lot for all the useful informations on this forum and for the schematics.
I also got mine in a bin, in a dirty state (traces of burn inside, fuses blown, short circuit inside).
I replaced the 4 leds (burned) and several cap and resitor around them (mainly for security reasons).
I cleaned everything and also replaced one 2SA1216 in short circuit, setted the biases to 12mv then the A3I was back to life and givign me a very nice sound.
Since then, I still have a strange problem: the 2 F4A250V fuses are occasionally blowing, the 2 at the exact samle time. The amp can work for 3 months without loosing its fuses or for only a couple of hours.
The mesured DC voltage is higher than it should (+38,8V, -38,8V), when it should be +34V -34V according to schematics.
AC voltage mesured is 29V/29V, but I cannot find the value it should be.
-What is your ideas for the reason of this over range voltage ?
-What should I check/do to fix this ?
Thanks a lot in advance,
Nicolas (from france)
Cambridge Audio 640C v1 Mods Thomo Digital Source 417 30th December 2012 03:52 AM
Cambridge Audio 340A SE preout conversion and other mods mikesnowdon Solid State 0 31st May 2008 08:00 PM
Cambridge Audio DacMagic 2i repairs query Fizzy Parts 3 11th January 2006 07:54 PM
Cambridge Audio CD5 Mods? edpgc Digital Source 7 9th May 2004 11:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
