Cambridge Audio A3i repairs and mods
Old 7th May 2008, 08:05 AM   #11
jaycee is offline jaycee  United Kingdom
This circuit is a very interesting one. Very unique VAS
x-pro, I presume this amp was designed to a budget. If you could make more exotic device substitutes and tweaks, what would you have done? My guess is you would have used a triple stage as you have already mentioned, and better driver transistors.
Old 7th May 2008, 12:30 PM   #12
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
Thank you, the VAS is indeed quite interesting - it combines a very high open loop gain and a good linearity for such a simple circuit. I've used a somewhat modified version of it (with fully balanced cascoded JFET inputs) in Creek Audio A52 series of power amplifiers.
These are obvious ways of potential improvement. A3i was made to a very tight budget. In general, this VAS could be easily coupled to another good quality output stage with good results.
Alex
Old 7th May 2008, 01:35 PM   #13
ppa is offline ppa  Italy
Hi All,
Alex, what do you think about the change of bd139 and bd140 with the MJE243/53 ? their pin sockets are the same but power and curret are both bigger in the seconds, moreover MJE243/53 are made by ONsemi and this is a guarantee.
Pier Paolo
PP
Old 7th May 2008, 01:40 PM   #14
Hi All,
I forgotten that in the a3i schematic C216/7 are inverted.
Pier Paolo.
PP
Old 7th May 2008, 01:44 PM   #15
x-pro's Avatar
Originally posted by ppa
Hi All,
Pier Paolo
Hi Pier,
yes, these look like a suitable replacement, thought according to the datasheet there is a noticable difference in a current gain between n-p-n and p-n-p devices. I may order some from Farnell to try and measure.
Cheers
Alex
Old 7th May 2008, 01:47 PM   #16
x-pro's Avatar
Hi All,
Pier Paolo.
True! My mistake - did not check the schematics properly . Sorry!
Unfortunately I can not edit the post now. Let's hope that this is such an obvious mistake nobody would fall for it...
Alex
Old 7th May 2008, 04:35 PM   #17
blue_dog1 is offline blue_dog1  United States
Originally posted by x-pro
Email me through the forum - I'll send you the schematics.
Cheers
Alex
sorry, tried. New user, my account is under moderation. Can you send it to me? Thanks a million.
Old 7th May 2008, 04:59 PM   #18
x-pro's Avatar
No, I can not email to you through the forum either. Please go to my web page and use email address from "Contacts" page (note anti-spam bits)
Alex
Old 12th May 2008, 01:02 AM   #19
x-pro's Avatar
Hi All,
Pier Paolo
Hi Pier!
here is an update. I've received some MJE243/253 and tried these in A3i circuit. They work very well - certainly better than modern versions of BD139/BD140. I also have measured the gain of these devices and from 50 of each all PNP have gain between 140 and 150, and NPN are mostly at 130, with a range from 100 to 150. I plan to make a redesign of A3i circuit for DIY and will probably use ON Semi drivers and output devices.
Alex
Old 12th May 2008, 01:50 AM   #20
G33/33 is offline G33/33  Indonesia
G33/33's Avatar
Alex
Hi Alex,
is there any alternatives for ZVP3306A ? I can't find it in Indonesia
can I use IRF 9610 / 9510 ?
rgds,
G33/33
Cambridge Audio A3i repairs and modsHide this!Advertise here!
Cambridge Audio 640C v1 Mods Thomo Digital Source 430 19th April 2017 11:31 AM
Cambridge Audio 340A SE preout conversion and other mods mikesnowdon Solid State 0 31st May 2008 08:00 PM
Cambridge Audio DacMagic 2i repairs query Fizzy Parts 3 11th January 2006 07:54 PM
Cambridge Audio CD5 Mods? edpgc Digital Source 7 9th May 2004 11:58 PM
