Old 1st May 2008, 02:41 PM   #1
Send a message via MSN to Franne500
Default Cambridge Audio A3i stopped working...
My A3i suddenly became VERY hot and stopped playing today.
I turned it off and gave it a rest for ca. 30 minutes. Then swithced it on again, and it played for 3 minutes, then it made a loud "pufff" and became silent.
I have checked the LEDs in it, and LED number 102 turns off when the amps makes the "puff" sound. It still gets quite hot.
Any ideas of what could be wrong ?
Old 1st May 2008, 03:46 PM   #2
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
Default Re: Cambridge Audio A3i stopped working...
Most likely it is either the LED itself or Q108 (BC640 transistor) next to it. If you send me a message through the forum, I can email you schematics for A3i. However just a replacement of these 2 parts most likely will cure the amp. LED can be replaced with any good quality green LED. Note: LED needs to be lifted at least 15 mm off the PCB and in a correct polarity!
Cheers
Alex
cambridge audio CD4SE Spdif not working elaar Digital Source 3 6th May 2007 01:44 AM
el84 1 channel stopped working help eddiedavies Tubes / Valves 5 2nd April 2007 12:32 PM
Advice on fixing an old amp that has just stopped working paulspencer Solid State 2 6th March 2007 06:39 AM
HELP! My remote volume control stopped working! :( paulspencer Analog Line Level 14 15th October 2006 05:34 AM
pinnacle 850 stopped working jamesj2 Multi-Way 1 14th February 2005 10:48 AM
Page generated in 0.07880 seconds (68.33% PHP - 31.67% MySQL) with 10 queries
