Old 29th April 2008, 10:33 PM   #1
aparatusonitus's Avatar
Default J-Fet folded cascade headamp, please critique
Hi word,
Schematic attached represents my first full discrete high power headamp (for mine 32 and 300R headphones), also I would like to use it as a small power amp during summer (already have a Class A SE mosfet amp for speakers, but it's way to hot to live with during summer). I want to know if there is something wrong with design, particularly if there is a better way to apply compensation. Power supply will be fully regulated and separated for input stage (few more volts then 24V shown) and triple EF buffer. Mind you, I am not an EE, I just keep an aye and take notes from big boys around this forum, so be nice, thank you!
Non é mai abbastanza...
Old 30th April 2008, 12:59 AM   #2
TzeYang is offline TzeYang  Malaysia
is it possible for you to post some square waves driving a 32ohm load?
Thanks.
Old 30th April 2008, 10:06 AM   #3
Hi TzeYang,
Thanks for replay...first image 1kHz step response just before clipping occurs driving 32 Ohms.
File Type: pdf jcx fc j-fet opamp v.1.7 pulse 1khz.pdf (14.3 KB, 62 views)
Old 30th April 2008, 10:09 AM   #4
Same condition 10kHz step response
File Type: pdf jcx fc j-fet opamp v.1.7 pulse 10khz.pdf (24.9 KB, 38 views)
Old 30th April 2008, 10:10 AM   #5
...100kHz step response
File Type: pdf jcx fc j-fet opamp v.1.7 pulse 100khz.pdf (25.6 KB, 46 views)
Old 30th April 2008, 10:26 AM   #6
does the current from D3 defeat the current mirror?
C1 looks a bit small, unless you have a very high source impedance.
What's the dissipation in each of Q17 & Q18?
Old 30th April 2008, 10:42 AM   #7
Hi Andrew,
Thanks for replay,...yes it does, but distortion without cascade are 30db higher (second harmonic)
Should I put something like 100pF instad?
It's about 220mW, a bit high for TO-92, but I would eventually put small heatsinks on them.
Old 30th April 2008, 10:49 AM   #8
can the mirror cascode be applied outside the mirror voltage sensors?
1k0 and cap ranging between 330pF and 1nF would be more effective.
4.6mA in the drivers seems a bit light for a 32ohm ClassA output stage.
Old 30th April 2008, 10:59 AM   #9
Probably yes, but I've not tryed that...but I will try that and report back.
Ok, thank you.
But standing current is twice as that?
Old 30th April 2008, 11:13 AM   #10
Gues you are referring to Q9/10/12/13 predrivers not Q23/24 drivers?
Quad 303 triple cascade hahfran Solid State 33 4th October 2012 12:46 PM
Tda1541a cascade circuit ash_dac Digital Source 0 19th February 2006 04:05 PM
JFET Cascade Line Amp wrenchone Solid State 13 1st October 2005 06:30 AM
the worth of a cap bypass (or cascade) sberube Multi-Way 2 3rd May 2005 10:20 PM
Copyright ©1999-2013 diyAudio
