Hello
On an amplifier Krell KMA160b, it I break down misses I a output voltage of the transformer, this tension will feed the stages driver. I sent an email at Krell industry without success, they do not want to give the plans of this amplifier, I must have this same breakdown service me, Know where to buy the same type of transformer that those used at Krell? Sorry for my pitiful English. Regards Pierre-Marie ( |
#2 |
I see that JWB with successful to transform its KMA into KSA, it has can be a transformer to sell ? but I cannot currently join it my statute does not allow it yet... :-(
Pierre-Marie |
#3 |
Hello
I do not have a voltage on these two connectors, and I do not see protections on the circuit Pierre-Marie |
#4 |
is there any power coming out of the transformer?
regards Andrew T. |
#5 |
Hello Andrew
I have a second block mono Krell, I compared the output voltages of transformer, all is identical, I have all the tensions on the part power the relays of exit go up, I miss only that of the photograph (drivers), and I do not have continuity in between the connectors, I am afraid which this part of the tranformator is cut, I would like to contact JBW but I cannot do it, I do not include/understand why that is refused to me. Regards Pierre-Marie "Sorry for English of my translator" :-( |
#6 |
your response confirms that power is getting into the transformer, so it's not the soft start and bypass that has gone faulty.
regards Andrew T. |
#7 | |
d'abord, tu dois placer plus des commentaires, je pense.
Looks like Sponge Bob has killed another thread. |
#8 |
Hello Holland:
I will make more research with a friend this after midday and will try to give you more information Regards Pierre-Marie |
#9 |
Salut, mon petit Bleu.
![]() Déja regardé a le transformateur sans la couverture ? (Inglese : you looky at transformer yet ?)
#10 |
Hello jacco vermeulen
I think that it is not possible to remove the cap of the trasformator, that all is moulded in the resin. I succeeded in sending a message JWB which already entirely dismounted to them his Krell industrie will give me Monday the price of a transformer, I believe that I will be afraid of the price Regards Pierrot |
| Page generated in 0.10129 seconds (71.70% PHP - 28.30% MySQL) with 11 queries |
