Homebrew Digital Sampling Audio spectrum analyser. - Page 2 - diyAudio
Old 24th April 2008, 02:07 PM   #11
I built the Cordell analyzer way back when I knew even less than I know now, if that's possible. It's really not that hard, except for the rotary switches, which have to be made up from many sections and joined together. Probably expensive today. I often recommend building just the signal generator board, if one needs a very good low distortion sine generator.
Another possibility for a nice programmable waveform generator are the Analog Devices DDS chips. Maybe a AD9953 or similar, though I don't know how good the distortion is.
I may be barking up the wrong tree, but at least I'm barking!
Old 24th April 2008, 02:11 PM   #12
jackinnj's Avatar
Default Re: Homebrew Digital Sampling Audio spectrum analyser.
Originally posted by G.Kleinschmidt
(an Analog Devices part, canít remember the part number ATM)
AD8307 perhaps?
Originally posted by Bonsai
Glen,
I looked at Bob Cordells distortion analyzer but it would be a bitch to build - too many boards/interconnects etc and a lot of the componenets are unavailable now.
Everything from Cordell's article is still available (including the LM1496 balanced modulator/demodulator-- this oscillator is the basis of the Tektronix SG505 -- i agree that it would be a real PIA to build the thing.
Old 24th April 2008, 02:22 PM   #13
GK is offline GK  Australia
Default Re: Re: Homebrew Digital Sampling Audio spectrum analyser.
Glen,
take a look at this
http://uk.geocities.com/cyrilb2@btinternet.com/
Might give you some inspiration/ideas with your project.
Bottom line is most people on the forum would love an easy to build, dedicated distortion analyzer with a 80KHz bandwidth i.e. a poor mans AP.
I looked at Bob Cordells distortion analyzer but it would be a bitch to build - too many boards/interconnects etc and a lot of th e componenets are unavailable now.
Some kind of pre-processor that fed into a PC or scope is probably the right way to go in '08.
Hi Bonsai.
I should note that a spectrum analyzer is a rather different beast to a THD analyzer. However, my design would mate nicely to Bob's unit to examine the spectral content of the extracted distortion residual.
Originally posted by jackinnj
AD8307 perhaps?
Old 24th April 2008, 02:42 PM   #14
G.Kleinschmidt]
All I have to do now is to find a decent low phase noise VCO IC to cover the relatively low frequency range of 800,000 Hz Ė 999,980 Hz.
Any suggestions? [/B]
What about the older synthesizer chips from CURTIS ELECTROMUSIC ? ONE VCO CEM3340/3345 PDF or DUAL VCO CEM3374 --> PDF
Well used also for example in the Roland's Flagship Jupiter-8
They are old but you can find still of them. Maybee in e-bay
the truth is somewere
Old 24th April 2008, 02:59 PM   #15
Please count me in. It is very interesting for me. I was using my PC audio card as frequency analyzer but I am not satisfied with the accuracy especially if I have to measure noise and distortion.
Dimitar
Old 24th April 2008, 03:36 PM   #16
Corax is offline Corax  Germany
Hi folks,
what do you think about this project with an ATmega and a graphic LCD with 122x32 pixel:
http://elm-chan.org/works/akilcd/report_e.html
Of course it won't be possible to measure distortion with that beast but it could replace the standard PA spectrum analyzer if you add a (digital) pink noise generator and a microphon preamp.
Old 24th April 2008, 07:13 PM   #17
jcx is online now jcx  United States
wouldn't an eval board for a 18 or 24 bit Msample monolithic ADC from Analog or TI be a lot more capable? and no 'scope needed for display - 2+ GHz 64 bit PCs should be quite adequate for dsp and display
http://www.analog.com/en/prod/0%2C28...7760%2C00.html
http://focus.ti.com/docs/prod/folder...t/ads8484.html
Old 24th April 2008, 07:56 PM   #18
jackinnj's Avatar
those starter kits and dev modules run $300 to $400+ once you figure in the additional stuff you need to get them to go.
i have the TI ADS1271 -- the devkit is $50, but the "PAK" and MPS430 tools were multiples of this
Old 24th April 2008, 08:20 PM   #19
See here:
200 MSPS acquisition board with ADC08200 should be enough
http://www.knjn.com/ShopFlashy.html
And in order to do FFT & DSP you will need FPGA:
http://www.knjn.com/board_Xylo.html
http://www.knjn.com/ShopBoards_USB2.html
In total it will come up for around $250 for freq analyzer + programming/configuring the FPGA.
D.
Old 25th April 2008, 12:54 AM   #20
Originally posted by jcx
[B]wouldn't an eval board for a 18 or 24 bit Msample monolithic ADC from Analog or TI be a lot more capable? and no 'scope needed for display - 2+ GHz 64 bit PCs should be quite adequate for dsp and display
I already have ~20 oscilloscopes in my workshop, and no room for another PC.
I pledge to work my nuts off over the next few weeks of evenings to get the display driver / sampling and double buffered screen memory board circuit design simplified with a little PIC here and there, using non-obsolete parts, layed out, operational and tested.
After that I will work on converting the <10Hz resolution ~90dB dynamic range analogue end and hybrid PLL working at 20-200,000Hz.
Glen
Visual Analyser & Nuova Elletronica LX.1690 KIT Oscilloscope + Spectrum Analyser fotios Solid State 25 9th March 2008 08:35 PM
HP 3480A spectrum analyser ian_elvar Everything Else 1 29th January 2008 07:39 PM
Homebrew Spectrum Analyzer Duo Everything Else 44 14th March 2007 09:44 PM
Which Spectrum Analyser?? fmak Parts 25 1st April 2006 05:08 PM
Copyright ©1999-2017 diyAudio
